is this normal after timing belt changed?
Old Jan 21, 2009 | 06:26 PM
B_Ray's Avatar
is TampaStock
Default is this normal after timing belt changed?
okay if you guys have read my previous thread my car has been in a shop for 3 days.
every time i accelerate it does not feel as powerful as it did when i had my old timing belt on....
like idk if its just because i have not driven it in 3 days or because the timing belt needs to be "broken in" or something?
any help here TR?
-Ben
[SIGPIC][/SIGPIC]
Old Jan 21, 2009 | 06:46 PM
PooN_Lude's Avatar
Check the timing.
Old Jan 21, 2009 | 06:53 PM
JoKiE crx4294's Avatar
popeye built!
+1 on the timing
Can't spell strength without tren
AAS...It's whats for dinner
Old Jan 21, 2009 | 06:54 PM
Tampa's_Slow_EG6's Avatar
Living in Black & White..
check that is not loose.. and timing...
Old Jan 21, 2009 | 06:56 PM
sleepinsol's Avatar
starting over
generally itl run better after a new timing belt bc it will be back in time (ie when the belt stretches the timing retards a bit, it should be more advanced now). recheck your dizzy/cam timing to make sure its on. but a butt dyno isnt really the best way to determine if a car is down on power.
Old Jan 21, 2009 | 09:21 PM
slo_hatch93's Avatar
TRShops Administrator
the timing is most likely retarded still
9/13/06-R.I.P. Kevin aka Slo Si, you will be missed
06-07-2006 01:47 AMSlo_Siwhen the spinnin ends, the bullshit ends...
xbox 360 gamer tag slohatch93
Jap Tuned!!
Old Jan 22, 2009 | 05:03 AM
wolfenr1984's Avatar
Great White Hope
You're the kid whose father took it to that shop, right? I bet they retarded it on purpose. I would first check your mechanical timing. I'm sure you probably don't know how to do that but you may be able to get some help from someone in your area. If that is off make it right and then set the dizzy to factory specs. Or right now, check your electronic timing to see where it is set.
"The richest man is not he who has the most, but he who needs the least
TR "Old Skool DA" Member #28
Old Jan 22, 2009 | 09:16 AM
sleepinsol's Avatar
starting over
if they only changed the timing belt, they should not have had to do anything to the distributor timing. and they really should not have had to move the cams. but if u wanna check the timing, just make sure all the marks line up on the cams and the crank pully.you could be a tooth off but if its stock cam gears i dont see that being possible.
Old Jan 22, 2009 | 09:27 AM
freakasis's Avatar
if this is the same shop as mentioned before....burn it to the ground.
and then check your timing....there should be no noticable differance after a timing belt is changed....unless it wasnt running before.
"Black people can't be racist" - Some black guy.
Old Jan 22, 2009 | 12:18 PM
DemonCivic's Avatar
put the engine at top dead center and check your cams timing marks. sounds like it may be a tooth off.
