D16y8 Flywheel + Boost Questions (Reps)
Old Jan 20, 2009 | 02:41 PM
3m0k1d's Avatar
Can't Take It With You...
Default D16y8 Flywheel + Boost Questions (Reps)
My cousin just ordered everything to boost his y8 and we needed to know if he should use the lightened 7lbs flywheel or jus use the stock flywheel? He wants to run a 10psi daily driver...
Old Jan 20, 2009 | 04:13 PM
tai mishuu911's Avatar
rut roh
too light for boosted. best is 11lbs.
so id say stay stock or get an 11lb flywheel.
N/A GSR on its way.
StricKly MT 727-510-6301
WIREWORX 407 388-5809
Old Jan 21, 2009 | 08:47 AM
95gainfla's Avatar
smokes weed...everyday.
zing. lightened flywheels really benefit for in the n/a cars. they spin too fast and youre changing gears before you even hit full boost.
I <3 RooR!!!!!!
Old Jan 22, 2009 | 09:45 AM
3m0k1d's Avatar
Thats what I thought, Thanx for the Help!
Old Jan 23, 2009 | 01:00 PM
CBURKE's Avatar
Has to many projects
WHAT!!!
It has nothing to do with it spinning to fast and you hitting boost........It just lightens up your rotating mass, makes everything spin easier. The only thing is a 7lb is more for racing and an 11lb is more for street use. You can use what you want you’re not going to hurt anything. Your tranny is what lets you stay in boost longer, right along with your turbo and how big it is. You need to be more concerned with the Y8 oil pump then any thing eels. There no good for high boost. These guys make one for that if needed:
Honda Performance - KMS Engine Development High-flow Oil Pump
Cburke.industries.
Custom suspension bars, metal fabrication.
