lsv cam siezing?? HELP
Old Jan 20, 2009 | 05:18 AM
boostedcoupe's Avatar
ok thanks guys. ill try and just smooth it out a bit and put my other b16 cam in there and see what happens with the correct caps for the A2 head
i really appreciate the help
Old Jan 20, 2009 | 05:35 AM
1fastsi's Avatar
Originally Posted by civicized
1. caps matched for head (the ones that came with the head from factory)
2. caps in order
3. good bearing surfaces on cams and caps
4. everything clean
5. a little lube
6. proper torque
if these conditions are met, you don't have problems normally.
Agreed, if you bought the head and the cam caps are from another head you have issues, you would have to pull the head take it to a machine shop and have them line bore it. It is so important to torque the head correctly, there is a torquing sequence for the cam caps and you need a torque wrench and you need to properly torque the bolts on. the only way your cams would hit the cam caps is they are the wrong cam caps or they were torqued wrong.
