car runs with no key in ignition....wtf?
Old Jan 16, 2009 | 07:43 PM
JoKiE crx4294's Avatar
popeye built!
Default car runs with no key in ignition....wtf?
how could this be possible? all the dash lights and the car will start and run with no key in the ignition. I have the starter and fuel pump wired to a switch. The elctrical part of the ignition switch is brand new from honda about 6 months ago. Let me know what yo guys think.
Can't spell strength without tren
AAS...It's whats for dinner
Old Jan 17, 2009 | 10:07 PM
So when the starter switch is no longer turning the engine, the fuel pump is still pumping fuel?..........Gotta be more to this story........-Bob
Old Jan 17, 2009 | 10:20 PM
custom240sx's Avatar
DC Crew Member #1
There doesn't have to be more to the story. I work on cars all the time putting stereos and alarms and the such in. Many GM vehicles after about 2001 use "chips" in their keys to keep you from starting that vehicle without the correct key. When you put a remote start in a vehicle like this you usually need a secondary key to mount in the vehicle somewhere so that the "key sense" can read that you have the correct key in the car and trick the vehicle into starting without it in the ignition...now that I have stated all of this...I have seen a few GM's that I could turn the key to the start position and start the vehicle, while it is running I could pull directly out on the key without turning it and the key would come out but the vehicle would still stay running and could be driven like normal. The key tumbler is bad or the key is worn out.
Old Jan 18, 2009 | 07:14 AM
popeye built!
i cant pull the key when it is in the "on" position, i have to turn it all the way back to where it locks the steering wheel. somehow it got stuck in the ''on'' position is what im thinking.
Old Jan 18, 2009 | 08:08 AM
Steve-O's Avatar
Fiat Specialist
did you make this post on honda-tech.com too? lol
im 90 DX Driver on there xD
could it be a bad key cylinder?
1990 Honda Civic DX Hatchback - SOLD
2006 Scion tC - Traded
2013 Fiat 500 Abarth - Current DD
Old Jan 18, 2009 | 10:12 AM
popeye built!
^^^yea its on there too
Old Jan 18, 2009 | 04:21 PM
freakasis's Avatar
sounds like the ignition switch isnt being turned...take the actual switch part off the back of the lock and turn it off with a flathead, see if that works...also inspect that whole area for wear and tear, somthing that might allow the key to turn without turning the switch.
"Black people can't be racist" - Some black guy.
Old Jan 18, 2009 | 04:35 PM
KwokLau's Avatar
b/p no pic's
Old Jan 18, 2009 | 07:15 PM
popeye built!
thanks man. Ill screw with it tomorrow
Old Jan 18, 2009 | 08:27 PM
omgwtfbbq!'s Avatar
I race sailboats
My buddy's integra had a worn out ignition and the key could be pulled out while the car was running, but you still needed the key to start/kill the engine.
Bitches don't know about the twin turbo
BLACK FENDER PART OUT
