d16y8
Old Jan 13, 2009 | 03:17 PM
crazyman1000's Avatar
born for boost
Default d16y8
does anyone know it I can use ls rods in a d16? also if I remove my IACV (Idle Air Control Value) coolant lines off of my throttle body would that cause any problems? plz help I don't know if i have correct information.
Crazyman
Old Jan 13, 2009 | 04:02 PM
born for boost
any one?
Crazyman
Old Jan 13, 2009 | 04:25 PM
born for boost
Crazyman
Old Jan 13, 2009 | 04:36 PM
freakasis's Avatar
you can use the rods but they must be bushed to accept the smaller wrist pin. and yes removing those lines would cause problems. leave them on there.
"Black people can't be racist" - Some black guy.
Old Jan 13, 2009 | 04:38 PM
custom240sx's Avatar
DC Crew Member #1
I have always bypassed those coolant lines and never had a problem.
LS rods also have to be shaved down on the sides and the blocks must be notched for them to clear.
Old Jan 13, 2009 | 04:55 PM
born for boost
how do i block off the lines?
Crazyman
Old Jan 13, 2009 | 05:24 PM
DC Crew Member #1
Find where the water enters the lines from the block and where it goes back into the block after passing through the throttle body...and just run a hose from the point before the throttle body to the point after. I know I seen a diagram floating around here before. It is called a throttle body coolant bypass.
Why do you want to do this?
Old Jan 13, 2009 | 08:44 PM
Derka's Avatar
TR Balla Donor Supreme
+1 on bypassing the lines, my hatch hasnt had them for years and even starting up in 35 degree weather in spring hill its fine
but honda did put them there for a reason, and there is no performance gain really, if the car is stock leave em. I did it just to clean up that area
1998 crv daily beater
Old Jan 14, 2009 | 04:37 AM
born for boost
people do it to take them off to keep heat away it.
Crazyman
Old Jan 14, 2009 | 04:43 AM
born for boost
is there any other little tricks i can do to my motor that people wont be able to see?
Crazyman
