timing issue....HELP PLEASE!!!!!!
Old Jan 8, 2009 | 12:34 PM
maT.T.'s Avatar
Default timing issue....HELP PLEASE!!!!!!
93 non vtech 1.5. just changed the head and gaskets and what not. ive lined up up the cam marks with TDC and ive also adjusted the distributor. the car runs at high RPM but is bogging bad at low RPM. is there a way to put a timing light on the timing belt?
im also having a surging issue at idle wich just started happening. and after about 20 minutes of driving i get a CEL. i checked the radiator fluid and its at the top. could this also be related to the timing being off??
this car is driving me crazy! PLEASE HELP!!! thanks....
Old Jan 8, 2009 | 03:15 PM
livebytheboard's Avatar
UNIQUE OBSESSIONS
yes it could be cause the timing belt goes around the water pump as well. did you make sure the crankshaft lines on the pulley lined up for TDC?
Old Jan 8, 2009 | 03:51 PM
Steve-O's Avatar
Fiat Specialist
when u line up the pulleys when putting on the belt make sure it hasnt moved any. sometimes itll move oh so slightly and cause it to be off. Clamp the belt to a cam so it doesnt move when its perfectly lined up and try that.
1990 Honda Civic DX Hatchback - SOLD
2006 Scion tC - Traded
2013 Fiat 500 Abarth - Current DD
Old Jan 9, 2009 | 04:44 AM
crix's Avatar
:mugen member:
sounds like ur a tooth off....surging usually because of the fast idle control under the throttle body=need to tighten nylon valve...
Old Jan 17, 2009 | 11:04 PM
Sometimes it is needed to back off/turn the cam about 1/2 tooth toward loose, put on the belt, tighten the belt back, then install the tensioner check cam timing with the belt tight, and lock it down.-Bob
