630whp on 20lbs
Old Jan 8, 2009 | 07:28 AM
StrictlyBusiness's Avatar
Mr. Stealyogirl
Default 630whp on 20lbs
Modified Car Trader.com | FOR SALE: 1995 Honda Civic ... | Winter Park Florida 32789 USA
Is that possible? Its only a pt67 but making that much power on 20lbs?
Tuners discuss.
www.jdmmindz.com
Lurkin' in a hood near YOU!
Old Jan 8, 2009 | 08:38 AM
JoKiE crx4294's Avatar
popeye built!
thers no way unless it was a dart head and block with a 95mm stroker. Alpha tuned one with that setup and on 18-19 psi made 620-630 i believe.....Thats why Alpha is the man. the pro3 cams lose power on a turbo setup.
Can't spell strength without tren
AAS...It's whats for dinner
Old Jan 8, 2009 | 09:00 AM
InsaneCivicCoupe's Avatar
Retired Ricer...
If the cams are degree'd properly and its got a good race gas tune on it, I dont see any reason why it couldnt make that power at 10,XXX RPM....
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Old Jan 8, 2009 | 09:48 AM
C-Cali's Avatar
HP does not = IQ#
Reving out to 10XXX won't help that much if his peak power is at 7XXX, for the turbo size, cams, cam gear he's closer to 400-500 not 6. race gas or not.
Driver Swag > Driver mod
FabThis<---Click This
Old Jan 8, 2009 | 10:06 AM
livebytheboard's Avatar
UNIQUE OBSESSIONS
still a nicely built car tho, they should have posted the dyno sheet and video taped it to prove it.
Old Jan 8, 2009 | 10:15 AM
popeye built!
The skunk2 pro 2 cams are I feel too large for a turbo application. I have tested them on gt42r/s372 sized turbos and lost power over the itr/ctr cams. There was significant midrange gains with them compared to the itr/ctr cams, but there was about 60-70 whp peak power loss. The cams were degreed into the engines properly.
and thats the pro2's. I imagine the pro3's are worse.
Old Jan 8, 2009 | 12:10 PM
Mr. Stealyogirl
From what Ive heard the NA sk2 cams are actually the best on boost.
www.jdmmindz.com
Old Jan 8, 2009 | 01:58 PM
popeye built!
The pro1's are the best.
Old Jan 8, 2009 | 02:24 PM
b15spec's Avatar
aint no reg. spec-v
all that power and the torque cut in F***ing half!
clean but honda's are so damn torqueless
https://www.tamparacing.com/forums/signaturepics/sigpic51275_1.gif
Old Jan 8, 2009 | 02:28 PM
Retired Ricer...
With that combination (Turbo, cams, headwork, etc... ) Im sure he is not making his peak power at 7k... You also have to consider the fact its a T4 framed turbo and probably has a pretty decently sized turbine wheel/housing combo....
