cluster questions
Old Jan 3, 2009 | 06:54 PM
UMMM?!?'s Avatar
BBAAAAAAH!
Default cluster questions
ok I have a 95 civic coupe and it has a d15b7 hydro tranny and my speedo is not working I took the cluster off and there does not seem to be any place to plug in a speedo cable as well as there is not one on the tranny. I know what I am saying may sound stupid but does anyone know what could be wrong or how to fix it?
Old Jan 3, 2009 | 07:00 PM
luvsracin87's Avatar
turbo hhhmmmm?
you dont have a speedo cable. it has a Vehicle Speed Sensor, it should be throwing a check engine light. if so check the connection on the 3 wire pulg on the back of the tranny, if that is good replace the VSS........one more thing CHECK YOUR FUSES(should prob. do that first)
Steve: (813) 810.4146 <~ call or text
Old Jan 3, 2009 | 07:03 PM
UMMM?!?'s Avatar
BBAAAAAAH!
I already checked the fuses and the 3 wire plug on the back of the tranny
all look good
Old Jan 3, 2009 | 07:06 PM
turbo hhhmmmm?
is it throwing a check engine?
UMMM?!?'s Avatar
BBAAAAAAH!
nope on when I turn on the key then it goes off like it should
Old Jan 3, 2009 | 07:13 PM
turbo hhhmmmm?
well then..... thats odd
Old Jan 3, 2009 | 07:15 PM
UMMM?!?'s Avatar
BBAAAAAAH!
I have no clue haha
Old Jan 3, 2009 | 07:17 PM
turbo hhhmmmm?
you could pull the vss and see if the gear on the sensor is messed up(never seen it happen but you never know)
Old Jan 3, 2009 | 07:25 PM
UMMM?!?'s Avatar
BBAAAAAAH!
I'll try it and let you know thanks for the help?
Old Jan 3, 2009 | 07:55 PM
UMMM?!?'s Avatar
BBAAAAAAH!
looks fine to me
