Diffrence between buddy club spec 3's and itr cams
+1 to what nick says! ^^ the colder the motor the better. LIGHT DRAG! and if you want to be real thorough adjust them in the firing order. 1,3,4,2. a bent feeler would be best to use but flat ones will work.
id say youre fine if you set the lash correctly the first time. if youve been beating on it then it may not hurt to do it again for good measure.
