what swap should i put in
Old Dec 24, 2008 | 09:58 AM
egsquad's Avatar
Default what swap should i put in
im planning on doin a swap in my eg from my stock engine...im thinkin bout either doin a d16y8 or a ls overall wat will be the best engine overall to swap in my eg but wont cost more than 1000
Old Dec 24, 2008 | 10:05 AM
00-Civic-Si's Avatar
i would do an ls swap b4 a d16y8 swap if u get the ls and later on if u wanna go ls vtec it you would be almost there really just depends on gettin a good price u could do an ls for less then 1000
Old Dec 24, 2008 | 01:35 PM
egsquad's Avatar
in order to go ls vtec do i need a whole swap or i just changed the head and ecu etc..
YARO's Avatar
Smith & Wesson Protected.
ls is a way better choice
-Induction Performance ALPHA Tuned.
-ROQUE MACHINE SHOP For ALL your fabrication needs.
Old Dec 24, 2008 | 01:38 PM
Codeine Fein's Avatar
ŁΘΘηεϒ ĝΘΘηź™
for ls/vtec you need.
Ofcourse, an ls block,(b18a1 or b18b1)
dohc vtec head, (b16,gsr,type r,)
Vtec water pump
Vtec oil pump
Vtec dizzy
Sandwhich plate
you need to tap the block
different timing belt
different head gasket.
im sure im missing some things
RIP. Keith Wallace
Old Dec 24, 2008 | 02:14 PM
JoKiE crx4294's Avatar
popeye built!
Vtec water pump
Vtec oil pump
Vtec dizzy
Sandwhich plate
Why do you need to tap the block? And you don't need a sandwhich plate
Can't spell strength without tren
AAS...It's whats for dinner
Old Dec 24, 2008 | 02:35 PM
rangcrx's Avatar
engine building &best
^ maybe he means plug the head. and you dont need a vtec oil pump or water pump,Ls are fine....but i would go with a nice ls motor also you will be happier with it then a Y8
i love AUTOZONE
Old Dec 24, 2008 | 07:58 PM
i was just sayin do the ls for now and it later on u wanna upgrade ls vtec it
Old Dec 24, 2008 | 10:08 PM
Paulino's Avatar
Not harsh, just truthful
The B18A1 or B18B1 (Ls motors) would be a greater choice for your Eg since the Eg is so lightweight and those motors are meant for heavier Integra's so you'll be ahead of the game and they are not to expensive.
