Tein spring OPINIONS!!
And here's a picture of them on the Koni shocks.
Oh Hai!
Oh Hai!
Kumar(my bro) with the sedan, is riding on s-techs and koni yellows on the lowest perch, and it rides pretty smooth imo.
skunk2 springs are like 2.25 all the way around, and thats about no wheel gap
and as far as the gc/koni, that setup costs like ~900, so i would rather get like some real coilovers like functionform etc
i think that'll be my xmas gift.....from myself!
To the OP, the last photoshopped picture.. there is no way you'll be able to sit like that with your S-Techs. You will definately have to look into coilovers. I was able to lower my car the way it sits since the Koni Yellows have adjustable perch levels.. One higher setting, and one lower setting.
Hope this helps.
Hope this helps.
"Success is 99% failure" -Soichiro Honda
call up Ground Control, tell them your car set up and they'll give you the set up you need inlcuding the spring rates.
I love my Ground Control and Koni setup. The Koni Yellows are worth the money.
Ground Control does manufacture their items to work with other shock set ups as well.
I have to give them props for their machining. Everything fits. The most we had to do on my CRX Konis was take off the paint on the c clip to make the coil over fit properly. Can't complain about that.
if you can only race me in a straight line then whats the point
...91 SMF SCCA
...91 SMF SCCAhttp://www.flickr.com/photos/8341770@N07/5601083432/http://www.flickr.com/photos/8341770@N07/5601083432/ by http://www.flickr.com/people/8341770@N07/, on Flickr
– the late Tom Thrash SCCA Solo E Production
