putting a gsr intake mani. on a d16
Old Dec 23, 2008 | 12:45 PM
markstheman365's Avatar
cant slide
Default putting a gsr intake mani. on a d16
i heard its possible, fill me in
contact admin@tamparacing.com to advertise on here.. - mod
Old Dec 23, 2008 | 01:36 PM
SmokinS13SR20's Avatar
That ginger...
Never heard anything like that, and sounds like a dumb idea to me.
Old Dec 23, 2008 | 02:11 PM
sleepinsol's Avatar
starting over
yea u would probably have to redrill the manifold to bolt up, and THEN figure out the water line and sensor issues. possible yes, smart? no. y would u want to use that intake mani on a d series?
i have heard of this on an all motor fully built non vtec b series, only becuase the butterflys in the manifold act like a mini vtec for large non vtec cams.
Old Dec 23, 2008 | 03:42 PM
Paulino's Avatar
Not harsh, just truthful
+2 on why you would even think of that in the first place. I mean i see where your coming from thinking it will make your car faster because of the extra flow of bigger ports of air but it still isn't work the sacrifice. My idea is if you want a higher flowing intake manifold go aftermarket.
Old Dec 23, 2008 | 04:34 PM
That ginger...
What do you have done to the motor to necessitate a new manifold?
Old Dec 23, 2008 | 06:37 PM
cant slide
thx paulino and everyone else, what kind should i get?
Old Dec 23, 2008 | 06:45 PM
Paulino's Avatar
Edelbrock makes nice manifolds and so do the companies that are mentioned the most like Skunk2 Racing, and Aebs..
Old Dec 24, 2008 | 01:34 PM
cant slide
i found spoon on ebay for like $259
Old Dec 24, 2008 | 02:22 PM
Skee's Avatar
or get your stock ported cut open and ported start with z6 better sohc to work off
Custom high amp Alternators.. pm me
Old Dec 25, 2008 | 06:20 AM
mtber's Avatar
Spoon does not make an intake manifold for your dseries.
Adding an intake manifold to your motor is not going to make a huge night & day difference. You should concentrate your efforts on compression & cam first. There after you should consider airflow.
