T-bracket not fitting b18
Old Dec 18, 2008 | 03:08 PM
B16delsol's Avatar
Default T-bracket not fitting b18
Hi, I have a B20 that I'm putting in my hatch and the rear t-bracket is not matching up? I put one bolt in and the other bolt wholes are just off by milimeters! I think the bracjets may be from an automatic, but would that make a difference? All B series crackets are suppose to be the same. I'm not sure why the T-bracket won't fit my B20. It's not SOHC! It's a DOHC B T-bracket and a B motor? ANy help, maybe auto is different? It's a gsr trans with B20 block, help me out.
Old Dec 18, 2008 | 03:20 PM
wolfenr1984's Avatar
Great White Hope
are you tightening up one bolt completely then trying to put the other one in or are they both loose when you try to mount the bracket? you may have to elongate the holes but I am no expert on putting a b20 in a honda by any means. try what I first mentioned then if that does not work, wait until someone with experience chimes in
"The richest man is not he who has the most, but he who needs the least
TR "Old Skool DA" Member #28
Old Dec 18, 2008 | 04:21 PM
custom240sx's Avatar
DC Crew Member #1
What year is the car for starters...I put a b20 in my EF with a b16 cable tranny and used a manual rear bracket from and LS integra. Bolted up fine.
Old Dec 18, 2008 | 05:07 PM
B16delsol's Avatar
It's an eg hatch!. I'm using a T-bracket off of an automatic 94+ teg. This is the first time I have ran into this problem but never my firdt swap. I just don't understand. The wholes just don't line up by a little. Also i'm not tightening then tring to match up and even if I do that it will still line up. Anyways any help on the info. if an auto. bracket is different from a 5spd one?
Old Dec 18, 2008 | 05:22 PM
Great White Hope
I think you know that answer already, lol
Old Dec 18, 2008 | 07:59 PM
DC Crew Member #1
lol yea I would find a manual one or oval out the holes if you want to be cheap like everyone else on TR.
Old Dec 20, 2008 | 04:06 PM
B16delsol's Avatar
^right. I thought they were different like the auto half shafts, but I thought I had done it before with an auto one, but I guess I was wrong, lol.
