oil coming out of my spark plugs what is it??
Old Dec 18, 2008 | 01:19 PM
DCLove05's Avatar
Originally Posted by gsxr0407
if it on the bottom side the part that sin the combustion chamber, it could be rings or valve seals.
that what I was thinking, do a compression test to make sure its not sour.
let us know what happens man
Old Dec 18, 2008 | 02:58 PM
wolfenr1984's Avatar
Great White Hope
if there is oil all in the cylinder, a compression test wont tell him much. if anything, it will tell him the cylinders are better than they are because of the oil in them; the oil acts like a sealant, hence the reason why the helms manual says to pour oil into the cylinder if you suspect bad rings.
when your motor burns oil, it is pretty obvious, just look at the plugs. shoot some pictures of the plugs you had/have in there and post them up if the tube seals don't stop the oil on the plug threads.
"The richest man is not he who has the most, but he who needs the least
TR "Old Skool DA" Member #28
Old Dec 20, 2008 | 12:26 PM
wearyfurball's Avatar
Could be a head gasket..
