need help...
mowchowbrowncow
on
need help...
okay tr my car has a mind of its own but just a few days ago my brake lights went out thought it was a fuse but pulled n replaced all my fuses and there still not workin im about to replace both bulbs even tho i dont see both bulbs goin at once.
Anyone have anyother opinions on wat it might be?
Pull everything apart & start examining your wiring harnesses for your tail lights.
mowchowbrowncow
on
Yep. I would suggest using the factory helms manual to trace the wiring
brake light switch. it has a plug on it, connect the two wires together and see if the lights come on, if they do replace the switch.
"Black people can't be racist" - Some black guy.
mowchowbrowncow
on
mtber-thanks ill make sure to do that tomarrow.
freakasis-were is this brake light switch under neith by the pedal assembly,could i had blown it by mashin my brakes?lol
yes thats where it is, no it couldnt.
