trans swap help
Old Nov 27, 2008 | 10:04 AM
freakasis's Avatar
you can see through it. it might have the rubber boot over it, depending on if someone has taken it out before or not. theres also a clip over it that you gotta pull/pry off. use a bolt to hammer it out, but not a honda bolt none of them are the right size, i used a bolt from an aftermarket battery terminal.
HONDA PARTS UNLIMITED... YOUR SOURCE FOR OEM HONDA AND ACURA PARTS AND ACCESSORIES!!!
# 12 and 33 in that pic is what your looking for
"Black people can't be racist" - Some black guy.
Old Nov 27, 2008 | 02:02 PM
custom240sx's Avatar
DC Crew Member #1
yup he is correct. sorry that I wasn't as descriptive I didn't feel like hunting the information down because I would basically be doing your work for you.
Old Nov 27, 2008 | 07:48 PM
tai mishuu911's Avatar
rut roh
id leave it in if i were you.
N/A GSR on its way.
StricKly MT 727-510-6301
WIREWORX 407 388-5809
Old Nov 27, 2008 | 08:03 PM
CivicSi91's Avatar
Kangaroo
well you have to remove it to drop the tranny from what the book says.
Mustang GT
"Life's journey is not to arrive at the the grave safely in a well preserved body,rather to skid in sideways,out of control,totally worn out,shouting Holy Shit, What a Ride! R.I.P. Ed Monroe (founder of A&E and SPW)
Old Nov 27, 2008 | 09:08 PM
freakasis's Avatar
you dont have to remove it, it just makes it easier. and if you do leave it attatched, make sure the shifter is pointing the right way when you put it back in. it can get turned around and then youll either have to pull the trans again or fight the bitch pin.
hell if you want me to take the pin out ill be free on sunday. PM me
Old Nov 28, 2008 | 01:45 PM
CivicSi91's Avatar
Kangaroo
So im ready to get this sh*t done an over with.
i hate driving my pos ford everyday.
i just really hate fords! only 12mpg
my civics = 30+mpg
Mustang GT
Old Nov 28, 2008 | 04:40 PM
  #17 (permalink)
DC Crew Member #1
the bitch pin is very easy to remove if you just go buy a 8mm punch...comes right out with a few small hits from the hammer. The bitch part is putting a new one back in.
Old Nov 28, 2008 | 07:18 PM
  #18 (permalink)
CivicSi91's Avatar
Kangaroo
yeah i figured nothing goes back as easy as it comes out
its the rule of life
but i mean in general i want it all done an to be over with. swapped an running perfectly
Mustang GT
Old Dec 2, 2008 | 03:28 AM
  #19 (permalink)
CivicSi91's Avatar
Kangaroo
need a new clutch for the D15b2.
what one should i buy? an should i buy the one for the D15B2 or the D16A6?
Mustang GT
