clutch probs. help!
clutch probs. help!
sometimes if i hold the clutch 2 the floor for a min(like at a light) it will stay 2 the floor n i have 2 pull it up with my foot.then it will work again. im not leakin fluid or using more fluid.when it stays 2 the floor i cant put it in gear,if im in first it stalls.thanx.
Bleed your hydro pump if not ether your clutch master cylinder or hydro pump is bad
HYBRIDWORKS
Performance Inc.
Repair shop / E-Tailer
"TR Member Discounts Available"
About Us
[/SIZE]
Performance Inc.
About Us
[/SIZE]
TR "Old Skool EF" Crew - Member #126
We Buy OBD1 Honda ECU's
Non-VTEC:$20-up
VTEC:$40-up
ECU'S WE BUY: P28, P06, P72, P75
Non-VTEC:$20-up
VTEC:$40-up
It might have a hydrolic leak. Check the master in the clutch. Or the clutch for or cable is broken. It would help if you stated what car, cable or hydo tranny, stock clutch and flywheel?
easy fix
HYBRIDWORKS
Performance Inc.
About Us
[/SIZE]
Performance Inc.
About Us
[/SIZE]
Non-VTEC:$20-up
VTEC:$40-up
Non-VTEC:$20-up
VTEC:$40-up
