vtec " controllers" and what they really do !!!
Old Nov 8, 2008 | 04:05 AM
got_bst?'s Avatar
Passed you
Default vtec " controllers" and what they really do !!!
so pretty much after reading this i realsized that if ur running stock internals and u talk about major H.p gains by just adding one of those then ur full of shit lol .....
There are two main VTEC/Fuel Control Piggy-Back computers on the market...
the Field's unit for approx $250http://store5.yimg.com/I/twincamtech_1686_704429
and the Apex'i Unit for approx $300-350http://store5.yimg.com/I/twincamtech_1690_921403
The difference? Just that the apexi has a cool display and has some extra features like a more accurate tach, vaccum pressure dispay, throttle percentage, some some other crap.
The only difference between the Apexi VAFC and SAFC is the fact that the VAFC has the ability to fuck around w/ the VTEC engagement point, other than that, they still have the same Fuel tuning capabilites.
Same goes for the Field's Vtec controller and fields hyper-R.
What these do is that when you tap in the appropriate lines on the ECU harness to the controller, it reads, and modifies the signal coming to and from the ECU to and from the sensors. This is why its called a Piggy-Back computer. It can also allow you to take away percentages of fuel in i think 500 RPM increments. Now, this should be done in conjunction with a fuel pressure regulator. Why take away fuel? Most ECU's tend to run rich...meaning too much fuel, too little air, which doesnt produce the full amount of power that it can/should.
Now before you all go run out and buy a fuel controller and lean the fuck out of it, remember: too lean, and you can cause detonation...which u dont want. So I dont recommend you just tune it on some back road. Go to a dyno place with a wideband o2 sensor and let them or if you think you can do it, tune it there.
From what I gather, the afc tuning is just done to smooth out the powerband and eliminate dips and spikes on your power curve, so that you can have a nice flat linear torque and hp curve. It should not really be used when you are in dire need of bigger injectors becuase the duty cycle is 100% by 4,000 RPM and you turn fuel pressure to 500 psi then try to lean it out with the afc. that wont work.
Anyway, that's what the AFC (air, fuel control) part does.
Onto the VTEC controller part.
VTEC engagement on a stock car is OPTIMIZED. Do NOT fuck with it because all you are really doing is taking away power, depsite what it "feels" like
Now that we have that cleared up...YES, i know that bringing the VTEC crossover up or down around 500 or even 1000 rpm up or down may indeed improve your power curves. Again, this is something u can only really prove if you are on a dyno and u can see the immediate results.
So, why do you need a vtec controller? U dont, really. Unless you are using aftermarket cams, or have upped the compression, or some other internal modification that demands a shift in the VTEC x-over to again be optimized. AGAIN, something you should really be doing on the dyno, as every motor is different, not to mention weather conditions, grade of gasoiline, general condition of the motor, etc....
So when you hear people say "I got a vtec controller and i set vtec to 3,000 rpm so im maddddd fast now son" u know they're a fucking idiot.
Why? This leads into my explanation on how vtec works but basically....
on a vtec motor there is a vtec cam lobe and non vtec primary & secondary cam lobes. Those non vtec lobes are optimized for low end power delivery. However, @ upper RPM, the small lobes cannot deliver enough air nor keep the valves open long enough to continue to let the motor make power.
Hence, the VTEC crossover...where the VTEC cam lobe takes over duties in opening and closing the valves from the seconary and primary lobes. Since the vtec cam lobe is much taller, it can now provide more air and duration the motor needs to keep making power @ higher RPM.
Now think about it. What does setting VTEC at 3,000 rpm do? It makes a cam lobe designed to work well at HIGH rpm to work at LOW rpm. Conversely, setting VTEC too high will cause the motor to start dying out, then JUMP foward when the VTEC lobes take over.
Its like asking allen iverson to play center against shaq. it doesnt make sense, and therefore, people shouldnt do it cuz its pointless.
If u have or do get a vtec controller, try it one day.
Set vtec to 3,000 and see how much of a pig the car is down low. Then set vtec to say 7,500 rpm or something. See how the car accelerates, slows down, then springs foward again at vtec x-over.
you may think that is the car making more power, but if you were to look at dyno graphs, you would see the torque curve fall off, then rise back up @ your specified vtec cross over point.
the above is also a good way to determine a starting point for an optimal vtec x-over when you have done some internal mods and u would like to set vtec @ a certain point. Take a dyno pull with vtec set low, then another pull with vtec set really high.
Overlap the graphs and where the curves intersect where power falls off and where power comes up is where you should start to fuck around with a crossover point
Old Nov 8, 2008 | 08:48 AM
BluRRboSi's Avatar
35.5 psi, stock sleeves
Thats alot of words...
PUREBRED PERFORMANCE
Fabrication & Tuning Services
813-451-7547 or 813-712-0202
Www.PPETUNED.com <~~ WEBSITE
Curious on honda/acura Ecu Chipping and dyno tuning? Call or visit the website above. Hondata/Neptune/Ectune/Crome Pro. Tuning available for most other systems and platforms as well. DYNOJET
Old Nov 8, 2008 | 09:21 AM
got_bst?'s Avatar
Passed you
but it's the truth
Old Nov 8, 2008 | 10:30 AM
Tampa's_Slow_EG6's Avatar
Living in Black & White..
it is the truth i didn't believe in vtec controllers before and now that i read the technical view of it im laughing at everybody with a stock motor and a vtec controller...
Old Nov 8, 2008 | 03:22 PM
D15superman's Avatar
EFsquad
even if the end user doesnt do any internal engine mods, with a different intake or exhaust manifold it can change the power curve enough to justify a small change in the vtec crossover. however i agree with you. piggyback units are total shit and should only be used for small on-the-fly adjustments to a car that has been built and tuned correctly beforehand.
Old Nov 8, 2008 | 08:40 PM
vonrobins's Avatar
love hondas ftw
i didnt even remember what a vtec controller was i havent heard of that in like 4 years
._________________________
Old Nov 8, 2008 | 09:21 PM
K20A2's Avatar
OH LAWD JESUS ITS A FIRE!
What?
-Winston Churchill
Old Nov 11, 2008 | 12:14 AM
SPOONCIVIC's Avatar
FUCKIN LOOONG BEDD!!!
vtec controller?...lol... no one uses that shit anymore!!! get with it man...
1995 called...it wants its tuning tool back
I BUY RROD XBOX 360'S FOR TOP DOLLAR!!!!..PM ME!!!
Old Nov 14, 2008 | 09:33 AM
USDM4g4d's Avatar
formerly D00MSB08
Lmao!
Thank you thread starter for filling us in on BASIC knowledge.
R.i.p My Big Brother Pablo Garcia III 9.28.85 - 9.05.07
The Man, The Myth,
The Legend.
Power Of DREAMS.
Originally Posted by K20A2
Nothing wrong with a B series
