vtec prob.
i was having the same prob with mines, i was told to check the fuel pump if that is messed up or dirt y it can cause that or a big thing is oil pressure, or oil pump starting to go bad.... but it could be a billion things
fuel pump has nothing with vtec not engaging. make sure the solenoid wire is not loose. make sure the spool inside is clean. make sure you have proper oil level. make sure you have good clean oil. make sure the connection to the solenoid is not dirty. check those things to resolves said issues.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
are you throwin any cel? if your fuel pump is bad you take a chance on leaning out. thats bad. dont go into vtec anymore till its fixed.
if vega said so go with it then.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
