Clutch Question
Old Oct 29, 2008 | 02:26 PM
lopezchris21's Avatar
Default Clutch Question
So yesterday i was driving my car and it just died on me. I came to a stop and tried putting it in a gear and it will just sit there. I would let go of the clutch while its in gear and no stall or anything. I hear something near the clutch sounding like something is spinning. The engine is a b17 and it has a cable tranny.
Can i use any b series clutch wit a cable tranny or do i need to buy a special clutch?
Please fastest way to contact me is call or text at 305-305-2968.
thank you and any input is much appreciated.
thanx
chris
TR 5th Gen Civic CREW Member # 04
Old Oct 29, 2008 | 02:47 PM
Evil_GST's Avatar
Pure Evil
did the cable break?? seen that before. but if your hearing noise from the tranny it could be a broken pressure plate
Old Oct 29, 2008 | 03:18 PM
the cable is still there and u can still see the lever moving up and down.
I can put my car in gear while the clutch is not pressed in......
Old Oct 29, 2008 | 03:47 PM
rangcrx's Avatar
engine building &best
then you clutch disc has broken you need a clutch from a 92-93 integra you can buy just the disc at autozone for 70bucks CP31184
i love AUTOZONE
Old Oct 29, 2008 | 04:09 PM
thanx man.
Old Oct 29, 2008 | 04:26 PM
wolfenr1984's Avatar
Great White Hope
you need a clutch for your transmission, not the motor. the output shafts on the b16/b17 transmissions are bigger compared to the LS transmissions. if you have any questions, take the old one with you when you get a new one or buy both and return the one you dont need...lol. carquest can get you an actual Acura/Honda factory OEM clutch for pretty cheap through a company called World Pack if you want OEM reliability.
"The richest man is not he who has the most, but he who needs the least
TR "Old Skool DA" Member #28
Old Oct 30, 2008 | 09:11 PM
so wat kind of clutches can i buy that will work on a b17 cable tranny?
Old Oct 30, 2008 | 10:06 PM
Old Renegade's Avatar
Cool Runnings
For the b-17 tranny which is the usdm GSR I think you need a actual clutch disc for a 92-93 teg due to the different size in shafts for that year.And that is the only years that the usdm had GSR teg's.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
Old Oct 31, 2008 | 08:04 PM
ONE SICK EK9's Avatar
Default clutch
thanx
chris
yeah man its either the clutch or the pressure plate, about a year ago the same thing happened to me. i was just driving and iwas accellerating and the car was not going any faster, when i took out the tranny the clutch disc was broken. i just went to tampa clutch off of 40th and bought a stage 2 4 puck dual friction clutch and pressure plate for like 250.00. ive had this clutch for a year and never had a problem
Old Nov 1, 2008 | 08:48 PM
thanx for the responses. i just dropped the tranny and the pilot bearing is rough as crap the clutch was worn like crazy, the flywheel was warped up the ass and the pressure plate was also gone...
