86 honda crx SI timing belt marking question
The car is a 1986 Honda crx si sohc fuel injected engine
the timing belt had snapped while driving. I am not sure if the engine is interference or not but Im hoping the valves did not get bent and engine runs fine with a new belt.
So Im at the point where im read to put the new belt back on but need help getting the cam pulley in the right spot and the crank at the right spot.
I see the two lines on the cam pulley but isnt there soppose to be the word "UP" on it? how do i know which side is up.
Also for the crank, what marks am i soppose to line up? I pointed out the marks i can see on the pictures.
Any help is appreciated, Thank you
anti-oval drift association
Team 15!
FUKUOKA JAPAN
anti-oval drift association Team 15!
FUKUOKA JAPAN
hmmmm, I am not sure about the cam but the crank pulley marks that you pointed to should line up with one another, as in the arrow should point to the line. bump
"The richest man is not he who has the most, but he who needs the least."
TR "Old Skool DA" Member #28
