cant get off crank pully!!!
Old Oct 16, 2008 | 03:42 PM
AllShowNoGo's Avatar
Default cant get off crank pully!!!
broke multiple breaker bars/impact sockets, used air guns but the dam thing wont budge any idea how else i can get the new timing belt on??
Old Oct 16, 2008 | 07:41 PM
ekcoupe's Avatar
IS FASTER THAN YOU
a snap on impact 3/4 drive will do the trick
Old Oct 16, 2008 | 07:56 PM
omgwtfbbq!'s Avatar
I race sailboats
If your impact gun didn't work you need a better impact gun.
Bitches don't know about the twin turbo
BLACK FENDER PART OUT
Old Oct 16, 2008 | 08:14 PM
CBowesracing's Avatar
Stock Built Beast
Not sure if you tried this, put a pry bar between the teeth of the flywheel, ( might need someone to hold it in place. or have it rest against the cement) then get the breaker bar and just start kicking at that bitch, and give er hell. Thats what I have always had to do. Its always worked.
www.myspace.com/chrisbowes
Old Oct 16, 2008 | 08:22 PM
YARO's Avatar
Smith & Wesson Protected.
+1 on the impact gun. An Ingersol Rand Titanium Max would eat that shit like cake. But if not available around you another way is to put it up i jack stands, 4th gear and have some one hold the brake then pry the fuck out of it. Need some one strong for this step.
-Induction Performance ALPHA Tuned.
-ROQUE MACHINE SHOP For ALL your fabrication needs.
Old Oct 16, 2008 | 08:49 PM
LOLWAT's Avatar
Registered-Honda-User
Is the motor in or out of the car? If it's out I'd do what he's saying. That's what I had to do when my impact guns weren't working.
Oh Hai!
Old Oct 16, 2008 | 09:08 PM
BOB's Avatar
BOB
Too Old & Too Poor
I ran into this problem over the weekend....we had MoeMoe stand on a breaker bar assisted 17mm socket, while Yblegal and I cranked like Hell on the flyweheel bolts and flywheel teeth until the crank nut finally busted loose.
Now rolling in a partial zero emissions vehicle.
Old Oct 17, 2008 | 04:41 AM
94TegDc's Avatar
you can torch the bolt and it will come right off with whatever impact you got
Old Oct 17, 2008 | 05:10 AM
Stock Built Beast
If its out of the car it wont work well. The motor would move around too much.
Old Oct 17, 2008 | 06:13 AM
wolfenr1984's Avatar
Great White Hope
One crank pulley holder, two breaker bars, and a 17mm or WHATEVERmm socket will allow you to get that beast off yourself.
"The richest man is not he who has the most, but he who needs the least
TR "Old Skool DA" Member #28
