rattling after timing belt changed.
I recently got my timing belt, power steering belt, and serpentine belt replaced by a TR member (don't like to name names, but still waiting to hear from him). Now, there is some squealing at start up and an annoying rattling noise when braking. But when accelerating everything seems and sounds ok. Any help? Wanna get this thing fixed!
White 96' Accord LX Coupe- My Final Project
The belts sometimes make that squeeling sound if they are overtightened or are slipping. Sometimes the timing belt does that too if the tensioner pulley was overtightened. As for the rattling sound...check your motor mounts and make certain they are all tight again.
Sounds like the belt is 2 loose and slapping around.
The timing belt is likely slapping the inside of the plastic cover because it is too loose. And as for the belts they are likely too loose as well and causing the squealing.
TR Old Skool EF Crew #24
engine building &best
on
rattleing maybe be from your timing tensioner not tight or the timeing is off and the rattle is from the valves,you may want to recheck the timing
i love AUTOZONE
i love AUTOZONE
Thats what I was getting at.
If the timing belt is rattling, but the tensioner is tight, then the tensioner could be bent. (this happened to my LS motor) As for the squealing, it is either the belt for power steering or alternator could be too tight or loose. Try and move them around and see if there is any tension on the two.
www.myspace.com/chrisbowes
can anybody direct me to someone or a shop that could fix this problem? hoping to get this fix asap. Thanks!
I dont know any shops out there yet, Im still in Colorado for a couple of months. Im sure if you ask, someone on here could give you a hand. Or you could get a chilton handbook for your car and find out how to adjust your timing, if you figure that out, then everything else is easy from there.
