LS Rods and GSR Piston Question?????
Old Sep 23, 2008 | 08:00 PM
coleon's Avatar
RedNeck Refab.Inc
Exclamation LS Rods and GSR Piston Question?????
I have a LS bottom end (91) and Have some GSR P72 Pistons, with rods.. I have been told to use my LS rods and utilize the P72 Pistons... Yes they have to be pressed, But from all the documentation, either the piston needs to be shaved, or the bottom of the rod needs to be shaved and balanced, Has anyone done this before, and have any advice.....
Im also adding a 2000 B16 head, with GSR cams, and retaining the stock B16 stock valve train, also Keeping the car OBD-0, usinga PR3 ecu..
Thanks Cole
Advice of any sort would be greatly apprechieted...
Thanks
And When It Rains.. It Pours..
Roughneck Refab .Inc
Old Sep 23, 2008 | 09:06 PM
mtber's Avatar
Mill the inside of the piston where the piston pin will slide through to clear the rods. I believe you will need to remove 1mm on each side. Take the pistons/rods to engine lab of tampa (enginelaboftampa.com) they have done it plenty of times.
You will need to re-size your ls rods if you are having arp rod bolts installed (recommended).
They can handle this as well.
Old Sep 23, 2008 | 10:15 PM
FrodoGT's Avatar
Found the Vtec switch.
Not to be a noob but why is it that he cant use the gsr rods?
TR Old Skool EF Crew #24
Old Sep 23, 2008 | 10:24 PM
mtber's Avatar
The GSR crank & rods are different then LS crank & rods
Old Sep 24, 2008 | 04:23 AM
KJ's Avatar
KJ
bored at work
b16a pistons fit ls rods with no mods, keep that in mind.
Old Sep 24, 2008 | 07:10 AM
JoKiE crx4294's Avatar
popeye built!
engine lab is garbage and way over priced i.m.o
Can't spell strength without tren
AAS...It's whats for dinner
Old Sep 24, 2008 | 07:11 AM
popeye built!
they wanted to charge me $200 to press my pistons off my old rods......yea syke. Eisles was $30.
Old Sep 24, 2008 | 05:04 PM
coleon's Avatar
RedNeck Refab.Inc
I know I have to use the arp head studs, so as mtbr recommended, 1mm on each side is what I have to do, what are your thoughts on my set up KJ, So do you think I should rather us the b16a JDM pistons rather than use the GSR Pistons??? Would you personally use the LS rods???? Thanks, Cole
Old Sep 24, 2008 | 06:14 PM
mtber's Avatar
I would use JDM p30 pistons as they make more compression then GSR pistons.
Old Sep 24, 2008 | 06:21 PM
wolfenr1984's Avatar
Great White Hope
p30 pistons are the way to go!!
"The richest man is not he who has the most, but he who needs the least
TR "Old Skool DA" Member #28
