Tuning Fuel Settins W/ VAFC
:Jack Daniels Addict:
on
I just put in an Autometer Air Fuel ratio gauge to help me to
tune my fuel settings through my VAFC. I know some of the basics
of what to do but can someone enlighten me on what to look for
how to read the gauge and what adjustments to make and just ALL
the information you can throw at me???????????
The Autometer...hell any of the air/fuel gauges that get their signal from the stock 02 sensor are pretty inaccurate. Youll mainly get a nice light show. The only time it will be really usefull is at full throttle where you can see how rich/lean you are running. You can tune the fuel map according to this input but it would be a wiser choice to get the car on a dyno and do it that way. But dont feel that it is useless or anything. You can still get data from it and tell the cars running condition. I know mine has helped me identify a bad ignition problem and a lean condition so far.
Guest
Posts: n/a
7u|\|1|\|g \^/17h0u7 4 \^/1d3b4|\|d 15 l1k3 7|2y1|\|g 70 \^/4lk 4c|2055 4 57|2337 bl1|\|d f0ld3d bu7 \^/17h 50m3b0dy y3ll1|\|g 47 y0u g1v1|\|g y0u 4dv1c3 0|\| \^/h1ch \^/4y 70 |2u|\|. Y34h y0u m1gh7 g37 7h3|23 bu7 7h3|23 4|23 b3773|2 \^/4y5. Ju57 my 0p1|\|10|\|.
Originally posted by "Someone"
Originally posted by LanceGSR
at full throttle its way rich should it be running more stoich?
I really wouldnt mess with it just wait till you get it on the dyno.
Originally posted by speed_daemon1
maybe but you cant tell how much.
200 points away from a 300
Guest
Posts: n/a
why are u spend money on egts and air fule gages when your an n/a car?
just a though i want to put in is that maybe u could buy something like pistons or cams something along that line insted of gages but its not my money
p.s egt only probly work effectively on trubo cars
As far as the whole why bother on an NA setup it is always good to monitor how your engine is running I think any car that is driven hard/raced should have at least an oil pressure guage and an a/f or egt guage. You can screw up an NA motor almost as easy as a turbo motor if you dont have your fuel and timing right.
