your H2B is weak
your H2B is weak
F2K is where its at, especially when its an F26
Honda-Tech.com: All Motor: 2595cc F20c motor
Originally Posted by jeremyinlinepro
I thought that I would share what I have been working on for the past six months behind closed doors. We will be running a fwd all motor car next year with our F2K conversion kit using the F20c engine. The engine is going to spec out to a 2.6 liter engine. I will post more pictures as the parts come in and I do more work on the engine. The cylinder head is mostly done and the parts are here for the block.
The cylinder head I have close to 50 hours in. The complete head was custom ported and valve work was done by me. The camshafts are custom billet pieces not available for sale. I did 2 sets with different specs. I have $2500 in each set of camshafts. The intake cam has almost 17mm lift and the exhaust is close to 16mm. Each with massive duration. This engine is going to rev close to 11,200rpm.
The engine is going to be 90mm x 102mm with 17:1 compression. The crankshaft is a custom billet piece.
lol mannn i have had a 2.6 4 cyl for yearssss.....in my truck boosted....what! lol
PM me for any AC, audio, and wiring work on your vehicle. Including but not limited to car audio, alarms, gauge installs, custom clusters, full troubleshooting, big/dual fuel pump relay kits, battery relocation, factory radio iPod and amplifier integration, custom harnesses, and custom standalone ecu installs and much more! If you need it done, we can do it! Don't be afraid to inquire!
i do like that tho...
I'm sure the dude building that didnt build it to cruise around town with lol....
