00 civic coupe wont start ...please help!
Old Aug 15, 2008 | 07:13 AM
3civicsxxx's Avatar
Default 00 civic coupe wont start ...please help!
So I was turning onto an intersection and the engine just shut off.....I try to turn it back on...........the engine turnsss but doesn't start......what should I do? please help.....
Old Aug 15, 2008 | 07:27 AM
Old Renegade's Avatar
Cool Runnings
my first thought is to check and make sure the timing belt is not broken.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
Old Aug 15, 2008 | 08:26 AM
Thatguysstuff's Avatar
Hey its that guy!!
^+1...
Fuel??
Spark??
maybe fuel pump crapped out..
main relay?
Old Aug 15, 2008 | 10:36 AM
bobbyex's Avatar
sounds like a timing belt
Old Aug 15, 2008 | 01:06 PM
JoKiE crx4294's Avatar
popeye built!
x3 happened to me. timing belt jumped some teeth somehow. just re adjust your timing if it f'ed up.
Can't spell strength without tren
AAS...It's whats for dinner
Old Aug 16, 2008 | 04:59 AM
sone's Avatar
check your dizzy.
Old Aug 20, 2008 | 09:11 PM
DsevenEm2's Avatar
lol if the timing belt snapped while running on the street, your motors done for good most likely. interferance motor you have there, equals pistons and valves smacking each other at high rpms.. equals bye-bye to motor
Old Aug 21, 2008 | 07:38 AM
jcarp613's Avatar
Originally Posted by Thatguysstuff
^+1...
Fuel??
Spark??
main relay?
Yup, Start with the basics...
Fuel. Turn the key the the start position, if you hear the pump kick on then you go to spark. If, not check your main relay.
Spark. Pull the plug wire off and put a plug in it. Rest it on the block and crank it. If it has spark go on to the next. if not, check the ignitor in the dizzy.
Check your timing...
There are several small factors in a Honda motor. Start with the small easy ones and work your way to the harder ones.
I wish you the best of luck. PM me if you need any help, or advise...
