I need help with my civic 90
Old Aug 12, 2008 | 06:50 AM
lakedives's Avatar
Default I need help with my civic 90
Im a girl first off. i have a 90 civic hatch, few months ago its started giving me problems( it would just turn off sometimes while driving... than it got worst till one day it didnt turn back on...
changed the starter, than gas filter, than pump, after changing the gas pump, it would turn on but than it would turn right back off. Now it just wont turn on.. wtf?? should i give up.. i really didnt want to, but i have no clue what to do, and it doesnt help that i know no one that knows about this stuff. and i dont wanna go to mechanics, im cheap, thats why i have this car... help please!!
Old Aug 12, 2008 | 07:09 AM
chi town brat's Avatar
! Ne shab'rud'ni !
It could be several things:
Does anything at all happen when you turn the key? Does the engine even turn over or is it dead at the ignition?
Is it manual or automatic? If it is a manual maybe your starter relay gave out or maybe the little plastic puck of life on the clutch broke. You will have little plastic chunks on the floor if it did. Very easy to fix.
It also sounds like it could be the main relay. It is located under the dash on the drivers side in the corner. Not easy to get to and be careful because you can break your dash when trying to get to it.
p.s. I am a female too but I don't see what that has to do with anything. Just post up what you need help with, ignore those that aren't helping and pay attention to those who will help.
good luck.
Old Aug 12, 2008 | 07:29 AM
Old Renegade's Avatar
Cool Runnings
might be the dizzy or the ignighter in the dizzy.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
Old Aug 12, 2008 | 10:51 PM
D15superman's Avatar
EFsquad
cars (basically) need 3 things to run, fuel, spark and air. the hardest part of fixing any car is figuring out the problem (for an amateur mechanic) i usually like to start by checking the ignition, 88-91 civics are Notoriously bad with their ignition systems.
Remove a spark plug, with it out of the engine plug the wire back into the plug then hold the plug very close to the engine itself (make sure you are not touching any thing metal on the car, only hold the rubber on the spark-plug-wire) and have a friend try to turn on the car. if your ignition is working the way its supposed to, you will see a tiny spark, if you DONT see a spark, try to hold it close to another spot on the engine to make sure you have a good spot, if there is Still no spark then you know its an ignition problem. if you DO have spark, check your other 3 cylinders.
Old Aug 12, 2008 | 10:53 PM
FrodoGT's Avatar
Found the Vtec switch.
I vote main relay as well. Have you noticed that the car dies or refuses to start mostly when its very hot out, like in the middle of the day for example?
TR Old Skool EF Crew #24
Old Aug 12, 2008 | 10:54 PM
EFsquad
because engines get air without any trouble, and if you have spark in all of your cylinders then you know its a fuel problem, in which case the relay, as the others pointed out, is a likely candidate
Old Aug 13, 2008 | 02:11 PM
CBURKE's Avatar
Has to many projects
I have 3 if you need one, there like 60 each, but you can have it for 10
Cburke.industries.
Custom suspension bars, metal fabrication.
Old Aug 14, 2008 | 08:15 AM
tampabitches's Avatar
TR Balla Donor Supreme
i put money on it that if you change the main relay your car will run thats what it sounds like to me.
91 CIVIC SEDAN LX TRADED
91 CIVIC HATCH B16A DX TRADED
97 CHEVY S10 ON BAGGES TRADED
98 CIVIC COUPE HX TRADED
91 CIVIC SEDAN EX TRADED
91 ACURA INTEGRA LS SOLD
91 CIVIC HATCH DX TRADED
93 FORD 150 XLT GOT STOLEN
92 ACURA INTEGRA LS TRADED
97 CHEVY 1500 350 TRADED
87 MAZDA B2000 TRADED
92 CIVIC SEDAN LX TRADED
92 CB7 LX SOLD
96 CHEVY S10 SOLD
92 FORD EXPLORER 4X4 TRADED
96 FORD F150 XLT TRADED
93 ACURA INTEGRA TRADED
95 FORD RANGER 4.0 TRADED
95 CHEVY S10 4X4 SOLD
Old Aug 14, 2008 | 01:19 PM
06F2fitty's Avatar
Car Freak.
Relay, most likely.. start there.. Good Luck.
And Believe Me i Know Plenty of gurls that know more about cars than me....
