Need help AGAIN with ek coupe
Old Aug 6, 2008 | 01:37 PM
AEballer's Avatar
Default Need help AGAIN with ek coupe
So I got a dizzy off somebody froms craigslist....put it out it ran perfect...ran good for 2 days...i went to go out to lunch on my break and the check engine light comes on it starts backfiring occasionally and bogs down..I took it back to work hooked up a scanner and pulled the check engine code...it was for the map sensor...idk if the timings off and the misfiring fucked up the map sensor or what I loosened the dizzy and turned it a little bit and cleared the code and 1/2 way home it did the same thing....anybody know something I dont that could help?
91 ef hatch-*SOLD*
94 si hatch-*TRADED*
95 240sx-*STOLEN*
95 LS integra-*TRADED*
92 CX hatch-*TRADED*
91 boosted ls teg-*TRADED*
B20 crx-*TRADED*
92 SI 4WS PRELUDE-*SOLD*
97 EK coupe *CURRENT*
Old Aug 7, 2008 | 01:07 AM
OMGVTEC's Avatar
Retired Moderαtor
did you check the cap and rotor to see if they look worn out, if so you can fix it temporally by getting sand paper and sanding down the contacts.
Old Aug 7, 2008 | 02:12 AM
mtber's Avatar
A map sensor has nothing to do with your distributor.
It sounds like your problem is related to wiring or your ecu/map sensor.
This kind of issue can't really be diagnosed over the internet.
Old Aug 7, 2008 | 07:53 AM
AEballer's Avatar
well if the time timing was off from the distributer and it misfires..cant that mess up the map sensor...i pulled off the dizzy and turned it 180 degrees and its running fine (for now)
91 ef hatch-*SOLD*
95 240sx-*STOLEN*
B20 crx-*TRADED*
Old Aug 7, 2008 | 09:17 AM
mtber's Avatar
Like I said, the map sensor has nothing to do with the distributor.
Old Aug 7, 2008 | 10:23 AM
JoKiE crx4294's Avatar
popeye built!
I know if i rotate my dizzy 180* it doesnt sit flush with the cylinder haed and it wont start. how did you get it to sit flush on the head?
Can't spell strength without tren
AAS...It's whats for dinner
Old Aug 7, 2008 | 11:05 AM
AEballer's Avatar
i did it at 11 at night and probably didnt notice it was sitting flush or not...but it still started and ran...both ways
91 ef hatch-*SOLD*
95 240sx-*STOLEN*
B20 crx-*TRADED*
