Anyone have a crank pully locker?
Old Aug 5, 2008 | 11:57 AM
Bftsupra's Avatar
Default Anyone have a crank pully locker?
Not sure what they call the special tool used to hold the crank pulley while removing the crank bolt, but I need to use one for a few minutes. I pulled my engine to try and fix some stripped/broken mount bolts, and need to get the crank pulley off to get the plastic timing belt cover off to get access to the broken bolt. It's a b18, any help would be appreciated, I am down south in ruskin, so someone in riverview or brandon area would be best for me.
Old Aug 5, 2008 | 06:06 PM
vonrobins's Avatar
love hondas ftw
if you can get a hold of air tools use them but if not get a 19 on a breaker bar and if the tranny is still on use a pry bar to put in where the starter goes to lock it up and break the bolt loose
._________________________
Old Aug 5, 2008 | 06:30 PM
sleepinsol's Avatar
starting over
3/4 inch impact to break it loose, and a half inch to put it back on...n ull never have a problem with it again. air tools are your friend on this one. ive fought with that damn bolt for hours on end before. it even got to the point where the breaker bar with the jack handle end extension and a BFH wouldnt do it.
