High compression nitruos motor
Old Jul 14, 2008 | 01:32 PM
skunked_rex's Avatar
window shopper
Default High compression nitruos motor
Ok whats the highest compression yuo would want to run on a nitrous motor down here that will pretty much always be run on 93
Old Jul 14, 2008 | 02:41 PM
Jap's Avatar
Jap
VTEC Out
I wouldn't do more than 12.5:1 for pump gas . Detonation is not your friend in FL .
Your going to need to pull a significant amount of timing for it to not ping on nitrous as well .
Hondata saves lives
Old Jul 14, 2008 | 04:15 PM
WonUpRacing's Avatar
I wouldn't run 12.5:1 unless you can get timing spot on. Maybe 11:1 or a tad more.
How big of a shot are you running and what's your set-up?
Old Jul 14, 2008 | 05:05 PM
juiced2ndgenteg's Avatar
+1 you always taking care of all the questions... I have ran 12.5:1 LSvtec but never sprayed it. Although most people I raced swore I was on the bottle. Ran great till my brother missed 4th and dropped a valve.(no rev limit wit a damn ebay chip ) Takes me back 4+yrs ago. Just fillup on some real gas when you spay teh bitch.
Old Jul 14, 2008 | 10:32 PM
Jap's Avatar
Jap
VTEC Out
With a good tune 12.5:1 is perfectly fine . Your going to as I said either need to pull ALOT of timing for nitrous or run a race gas cell for it .
Hondata saves lives
Old Jul 15, 2008 | 12:18 PM
window shopper
Well ill prob be running a 50-75 shot with rods and itr pistons and prob a thick head gasket... B16 head most likely.. then prob step up to a hundred shot once i build the head id want a reg tune and a spray tune of course
Old Jul 15, 2008 | 12:30 PM
window shopper
Yeah i think i may run jdm itr pistons with a 2 layer gasket which should put me right about 12.5:1 thanks for the input fellas
Old Jul 16, 2008 | 09:58 AM
why waste your money on rods and put stock pistons on them? stock rods with arp rods bolts will be more than enough for a setup like that. If your going rods, BUY SOME REAL PISTONS.
Old Jul 16, 2008 | 11:47 AM
YBlegal's Avatar
Broke not Built
^ +1...
working my way back up...
Originally Posted by JoKiE crx4294
What do i have to prove to anyone?....umm NOTHING!!
Old Jul 16, 2008 | 04:13 PM
window shopper
because im gonna build it anyway im only gonna run this setup until i pieces together a nice turbo setup and then switch out the the pistons for some forged low comp pistons
