Gsr Fuel Pump Question ??????
Old Aug 5, 2008 | 08:40 AM
PasswordDC2's Avatar
Angry Gsr Fuel Pump Question ??????
my car gets spark but not fuel so i got a new fuel pump ..havent installed it yet. what if it done start with a new fuel pump??what could be the promblem
Old Aug 5, 2008 | 08:44 AM
CBURKE's Avatar
Has to many projects
Can you hear the pump come on?
Cburke.industries.
Custom suspension bars, metal fabrication.
Old Aug 5, 2008 | 08:49 AM
CBURKE's Avatar
Check to see if you can hear it. Turn the key to the ON pos but do not turn the car over. If you hear it buzz then it is on. If not check your fuses and main relay.
Cburke.industries.
Old Aug 5, 2008 | 09:14 AM
no i dont hear it new fuel pump and main relay
Old Aug 5, 2008 | 10:47 AM
CBURKE's Avatar
You put the pump in yet, sounds like it to me, unless you are not getting any power coming from the ECU.
Cburke.industries.
Old Aug 6, 2008 | 05:53 AM
OMGVTEC's Avatar
Retired Moderαtor
omg i had this same exact problem, turned out to be a fuse under the dash but i tried everything, does ur check engine light stay on? possibilities include
1. Bad ECU
2. Bad Ignition switch
3. Ground near the starter could be dirty or loose
