honda ECU question Mtber,alpha,anyone
engine building &best
on
i love AUTOZONE
i love AUTOZONE
It is the primary c14 cap. If the cap fails, the ecu won't work.
on
what would make it Explode/heat up and burn right thru....as you can see i tried to use one from another ecu i had and run a jumper but im trying to find out what would make it burn out and there car just die"well i am guessing this is why the car died"
Shot with SAMSUNG at 2008-08-04
i love AUTOZONE
i love AUTOZONE
on
its a 94 civic ex d16z6 automatic
i love AUTOZONE
i love AUTOZONE
catalytic aging.
When they get old they leak, overload and either stop working or blow up like a mini pipe bomb.
Honda of Wesley Chapel Crew Member #1
TR 5th Gen Civic CREW Member # 07
TR H2B crew #2
__________________________________________________ _________________________________________________
TR H2B crew #2
Capacitors fail on any electronic device over time. Capacitors don't last for ever.
Capacitors are in many electrical devices we use every day such as personal computer mother boards, tv's, radios etc.
It appears that the cap in the ecu you have has been replaced with a cap which is not the same brand/quality of the OEM cap originally used.
Generally when a capacitor fails it will damage the circuit board so badly that traces in the ecu are actually burnt so bad that they can't be re-used.
on
oh it did it burned a hole right thru the board,the cap you see in the picture is one from a p73 Ecu i had around i zapped it out and tried to fix there ecu, so it is from just old age,nothing from the wireing harness could make this happen i installed the p73 the car stumbled but fired up
i love AUTOZONE
i love AUTOZONE
