spray on a sohc
+1 i sprayed my 230,000 mile d16y7 for a year on a 75 shot i went through 2 bottles a week at some points and the worst that happened was clutch went and melted a valve both were cheap and easy to fix.
Married to EkCoupegirl
Current Cars
05 ZX6R FOR SALE! Help me pay for school PM me for info.
95 Civic EX 4dr- D.D.
99 GMC Sierra 5.3l ext. cab. Under construction
05 Kawasaki Ninja ZX636R Plasma Blue
Current Cars
lol than listen to your boY!! Seriously you can spray a stock motor as long as is running healthy and is 50-75 shot or less..
-Induction Performance ALPHA Tuned.
-ROQUE MACHINE SHOP For ALL your fabrication needs.
It's been a while for me...
Depends on the type of setup you're running, and how much you want to spray. I've seen stock Y8 motors take 100+ wet.
The key to keeping the motor healthy is to keep the A/F ratio in check. Generally the D series bottom ends can handle around 200whp safely.
If you're going for cheap horsepower, I'd stick with a 50 dry shot and call it a day. Back the timing off a bit if you're worried.
Unregistered Linux user since 1995.
What the heck is "O" Boost?
http://www.twitter.com/jeffc_sunbelt
sfodder@sunbeltsupport.us
jason on the forums here ran a 150 shot tuned on an all stock d16z6...
Current Cars
Current Cars
I am running a stock z6 with a 100 wet shot and i made my valves purple lol but the compression on the block is 179-182-180-182 I will throw another head on and keep spraying ha
