prob with my 96 sohc
Old Jul 20, 2008 | 05:04 PM
-campy-'s Avatar
Default prob with my 96 sohc
aight so here is the prob. that i am having first i my check engine light is on when i hook up my modis (snap-on) diag scanner it shows no comm. to pcm so i checked all the fuses and there where a feww that where blow so i replace them and still no comm. than i call hotline and they tell me to holds the reset button on the side of the pcm and the the check engine light should flash multiple times. but did that no flashing. and still no comm. to pcm that is a prob. because i have to get and inspection and you cant with the light on ok.
prob. 2
while driveing in any gear and mid range rpm the car looses all engine power like a really bad bogg than i let my foot off the gas and go full throttle and the car pulls like its built but the prob. is only intermitten i have done a complete tune up plugs wires filters oil change but the prob is still there. and it has an erratic idle some times again intermitten please ht help me out
Old Jul 20, 2008 | 10:59 PM
mtber's Avatar
Check the codes using the service connector jumper method.
For more information read http://www.phearable.net/tech
Old Jul 21, 2008 | 08:17 AM
zeroboost1's Avatar
John is right, just jump the service conector and read the mil on the dash.
The modis is garbage I gave mine back to my snap-on dealer and he gave my old snap-on scanner back That thing never fails even if it is old school.
Anyway good luck with the car.
CAM-Mobile-Performance&Repair
For All Your Performance And Repair Need's
Done At Your Spot Or Mine.
I do every thing from ECU chipping, swaps and custom wireing to audio and alarms, even suspention and alignment's.
We will be tuneing very soon E-MAIL me at CAMPERFORMANCE@yahoo.com
For any questions or to set up an appt.
Cory .M
Old Jul 21, 2008 | 11:28 AM
killswitch95's Avatar
john is right that works really good also just a reall odd thing to try but try using a diff set of injectors sounds just like the problem ive had, good luck
TR 5th gen civic crew #42
Old Jul 21, 2008 | 03:00 PM
-campy-'s Avatar
ok so next prob when i jump my cel i have nothing no flashing of any sort but the check engine light is on
Old Jul 21, 2008 | 03:10 PM
mtber's Avatar
Sounds like you may have a faulty ecu.
Old Jul 21, 2008 | 03:20 PM
-campy-'s Avatar
thats what i honestly was thinking alright thanks john for all your help and do you think that has anything to do with the bogging by any chance
Old Jul 21, 2008 | 06:08 PM
slicshoes's Avatar
mine wont go off i tried the jumper wire deal n it gave me a code 13 barometric pressure wats that about? is it serious?
Old Jul 21, 2008 | 06:40 PM
mtber's Avatar
Yes
