Need Help Wiring Up VTEC (Bought Subharness)
Well, Bought Another Pressure Switch, Still No VTEC!
Well, I just recently bought another pressure switch (was time for one anyway) and I noticed I was still having the same CEL's. So I called a friend (Shayne from Lakeland) and asked him WTF was up. He said take out the hazard light fuse to reset the ECU, so I did, and no CEL!!!. So I take the car around the block (mind you, I have everything hooked up but the knock sensor, at operating temperature and all) and I get to 5500, no VTEC!!!!
WTF do I do now?
WTF do I do now?
Nikon D7000 | 18-55mm kit lens | 55-200mm VR | 50mm 1.8G |
GoPro Hero 3 Black Edition
Everything you need including how to bypass vtec pressure switch is on Phearable.net - Electronic Fuel Injection Tuning Solutions - Hondata, Neptune, Crome, Uberdata, Ectune, AEM, Honda Tuning, Widebands, Fuel Pumps, Intercoolers, Turbos, LS/VTEC, ECU Chipping, Chipped Ecus, P28
My question is the actual connection to that tab, like how the heck am I going to feed it into the connector plug that I have when it doesn't have one? It's the same as the Rywire sub harness but my solenoid doesn't have a connector on it. Just that wire hanging from it... I've checked your site multiple times, maybe I'm just not going to the right area...
you may need to buy a new sensor because that one is pretty FUBARed!!
"The richest man is not he who has the most, but he who needs the least."
TR "Old Skool DA" Member #28
I know the sensor is, I posted that.... I'm talking about the solenoid.. Look closely at the picture again of the wire coming off the solenoid, if I have to, I'll get a closer pic for you
You have no connectors for your solenoid or vtec pressure switch. Simply directly wire it or get a plug from a bad solenoid etc...
put one of these on the solinoid and put the other end on the harness you bought
RadioShack.com - Cables, Parts & Connectors: Connectors & connectivity: Crimp connectors & terminals: Insulated Heat-Shrink Disconnectors (8-pack)
done
done
Yeah... nice of you to let me know that...
