95 Acura Integra starting issues.
Old Jul 14, 2008 | 01:54 PM
Hellfire_Studios's Avatar
Default 95 Acura Integra starting issues.
I have an integra in my shop right now. The car will not start. It turns over and has spark but no gas. I have dropped the tank out of the car and it was full of rust (its been sitting for a while). Also when you turn the key on you do not hear the pump turn on like a car usually does. I have also cracked the fitting loose at the fuel filter and its bone dry.
I need some insight from a honda/acura person as I am a painter by trade and not a real strong mechanic.
I think I should put a new pump in it and a new tank due to the rust. Change out the filter and add new gas. Please let me know if you think I am on the right track.
The only thing I didn't check was the fuel pump relay/fuse due to me not being able to find one. let me know if I missed something please!!!
Josh
Josh @ Hellfire Studios
Custom Paint, Collision, Bikes
<Severed Ties> FL
"Diamonds are forever!"
Old Jul 14, 2008 | 02:19 PM
DemonCivic's Avatar
connect a test light to the fuel pump power wire and turn the key to the on position, if you have power to the pump you need a new pump, if not check the relay. g/l
Old Jul 14, 2008 | 02:30 PM
where is the relay located? I could not find it in the place under the dash nor in the place in the passenger side of the engine bay. Can you point me into the right direction.
Josh
<Severed Ties> FL
Old Jul 14, 2008 | 04:51 PM
Thatguysstuff's Avatar
Hey its that guy!!
I think its right there under the dash on the driver side..
check this web page.. it will tell you also how to fix it..
Acura Main Relay Location
Old Jul 14, 2008 | 06:35 PM
thanks...it is a big help. I will give it a shot.
Josh
<Severed Ties> FL
