vtec wiring homebrew vtec controller
Old Jul 14, 2008 | 01:33 PM
Chronik Fab's Avatar
Default vtec wiring homebrew vtec controller
i want to use a tac with an adjustable shift light to control my vtec, does anyone know which wire gets the tac signal, or if this will even work. im pretty sure all it needs is a signal and a shiftlight will give it at the correct rpm.
Old Jul 14, 2008 | 02:14 PM
chimmike's Avatar
They call me Harry
there's a bit more to it than that.
01 Sentra 1.8 turbo (sold)
91 Sentra SE-R turbo (sold)
03 350z turbo (RIP)
07 Mazdaspeed3
Old Jul 14, 2008 | 05:36 PM
freakasis's Avatar
if yer talking about tuning a non-vtec ecu to run vtec it will sorta work the way your thinking....but it still wont be right....just get a vtec ecu and get it chipped...the right way is ALWAYS the better route in the end.
Old Jul 14, 2008 | 06:29 PM
jonathan1307's Avatar
Default alternative...
I have a msd rpm activated switch (can change between rpm "pills" to cut on vtec or whatever accesory u would want to hook it to) that i will let go cheap if you are interested, it was used on my old H22 accord for the vtec, but like what you are saying about using the tach, you would need to adjust/raise the fuel flow from the rpm when vtec engages all the way to redline to get the full potential of the motor, i used this and a safc before i found a p13 ecu for the Acclude and ran a couple tenths of a second quicker in the 1/4 with this setup...although prolly not as safe as the vtec ecu
Old Jul 15, 2008 | 12:09 PM
well, i have a 97 prelude with the jdm f20b. i am new to honda coming from diesel, so im trying to adapt my rigging skills. if anyone will help me im trying to get some honda buddies.
Old Jul 15, 2008 | 04:31 PM
where are you located around? i dont have a honda now but it is all i use to have, and what i miss deeply now lol, and i'm looking for any buddies (new to the area with basically no friends here) havent actually seen it done from the tach but i dont see why it wouldnt work, just have to make sure to address the fuel starvation while in vtec somehow to get good power, if not you will run lean in vtec and have MUCH less power than you the motor should be making
Old Jul 15, 2008 | 06:34 PM
i live in brandon. i only want to set vtec to engage at 4500. its just because i have 18" wheels and when i shift it drops to 4500. i was deciding between this and putting a manual trigger button on the shifter so i could run it on stock settings or engage it at will. this is only temperary until i build my turbo manifold. does anyone know if it is a common flange on the f20 so i can cross refrence?
Old Jul 16, 2008 | 07:00 AM
the f20b is uses the same head casting as the h22 just with different cams and may have slightly different sized ports, so the exhaust manifold flange would be the same for the two
Old Jul 16, 2008 | 08:11 AM
basically all of the turbo kits out there for your prelude will be the same as on the stock h22, prolly be a lot cheaper and have a lot less r&d than building one yourself, the only physical difference i would think between the f20 and the h22 would be the height of the block, which might mean you need a slightly shorter intercooler piping
1990 accord H22/nitrous-(was my first car)
1995 integra ls stockish-sold
2004 blazer to pull around the project cars-sold
1990 crx hf-ls/vtec drag car project-sold
1989 civic hatch was going to use for drag project but didnt happen-scrapyard
1992 civic hatch vx jdm d15b turbo-(carbon monoxide poisoning almost killed me)-sold
1992 civic hatch vx semi-built d16z6 sc61 turbo-sold
1980 280zx ugly slow pos-scrapyard
2006.5 kia optima i bought to keep myself out of trouble-only current car
Old Jul 16, 2008 | 12:21 PM
where can i get a cheap kit? i just wanted to build the expensive stuff, like the headers and the downpipe.
