D15B7/Z6 single-cam vtec problem.
Old Jul 6, 2008 | 02:48 PM
gypsykasket7's Avatar
Default D15B7/Z6 single-cam vtec problem.
d15b7 block with d16z6 vtec head, got problems, if anyone has any suggestions, it has proper spark to all plugs, getting fuel, relays are good, all engine grounds are in place, turns over like a champ, but won't fire, quick response would be very appreciated. thanks.
Old Jul 6, 2008 | 03:04 PM
redcoats1976's Avatar
coil bad?
Old Jul 6, 2008 | 03:29 PM
wolfenr1984's Avatar
Great White Hope
if it's getting spark, has fuel pressure, and is properly grounded, it should fire. but check the coil with a ohm meter to test it out. refer to this website to get an idea of what you're looking for, Advanced Ignition Troubleshooting - Team Integra
i know that isn't your motor, but it is pretty similar as far as operation. hell, you may have some loose connections within the distributor which are only noticeable once you take the cap and rotor off! it's worth the shot!
"The richest man is not he who has the most, but he who needs the least
TR "Old Skool DA" Member #28
Old Jul 6, 2008 | 06:27 PM
k, thanks guys this shit is just really irratating me badly.......could it be the whole dizzy?? or just the internals, i'm jsut wunderin cuz i haven't done a honda since high school and thats been like 5 years so i'm kinda rusty at this, but just get back to me asap, and thanks again for the help, i'll try it 2marrow after work...
Old Jul 7, 2008 | 09:22 AM
ElektroBass's Avatar
YOU WONT!
is the timing right ? cause i had the same problem and i had to turn the crank 180 and it fired right up
Let The Good Times Roll
Subie Life!
Old Jul 7, 2008 | 10:13 AM
Scott90's Avatar
Ecotec y0!
your original post didnt say if you checked the ground, look at the negative baterry terminal, follow that wire till you see where it grounds out onto the blow, take it off, clean the connection areas and put it back on.
i just had to do this to my moms accord, the wire was shreaded a bit and everytime any water touched it, the car would not start, so just put electrical tape around the exposed wire and it fixed everything.
good luck with everything, but definately try the grounds. its quite common with Hondas
"Decide what you want, decide what you are willing to exchange for it. Establish your priorities and get to work."
Old Jul 7, 2008 | 12:35 PM
yes, all of the grounds are good and clean, i just don't get it at all.....but i'll try out the mentioned above, and let you know if it doesn't work, thanks for all the help......i'll get back..
