Weird problem
Old Jun 29, 2008 | 07:01 PM
civicSi07's Avatar
Default Weird problem
To start off i have a crx with b16. everything was great til i put my s2000 cluster in. Everything works fine its just that I only have vtec in 1st and 2nd, and wont pop it in 3, 4, or 5. Just the other night i got a code 17, which is vss, but it shows the speed just fine. And sometimes when i take off in 1st, it hits a rev limiter at like 4k? its really weird. And if i floor it in 2nd, it feels like power just dies off around 6.5-7k.
Any ideas?
Also what is a b16's stock fuel pressure? i have it set at 32psi.
1992 Honda Civic Si: SOLD
2003 VW Gti 1.8t: SOLD
Most recent: 88' B16 Turbo CRX: Totaled
PM me if you know me!
Old Jun 29, 2008 | 09:01 PM
sleepinsol's Avatar
starting over
woa....vss wont let u go into vtec for 1. but the rev limit at 4k? do u have a 2 step set at 4k? if so when the speedo reads 0 then u wont be able to rev past 4k. but if ur reading speed just fine then there must be a bad connection between the vss wire and the ecu or something like that. this is odd.....can i see pix of the s2k cluster in the rex tho? lol
Old Jun 30, 2008 | 12:06 PM
civicSi07's Avatar
its not like a rev limit exactly, maybe like a fuel cut or something and its when driving not sitting still. and only happens every now and then in 1st or 2nd when going WOT.
Ill put pics up when i re-do my carbon fiber surround. right now it looks horrible.
Anyways i guess ill check my connection for vss at wire b16 at the ecu. but what would be the reason for power dropping off at like 6.5k?
Old Jul 1, 2008 | 11:19 AM
civicSi07's Avatar
anyone?
