Higher Compression
Old Jul 26, 2001 | 11:11 AM
AcuraCivicSi's Avatar
Im doing Ls/Vtec and want to increase compression from my stock 10.2 to 11.0 - 11.2 Or atleast increase comprssion to 10.6 What would be the most cost effective way without having to use cam gears or after market pistons?
CTR pistons?
JDM ITR pistons?
Oh by the way im keeping the stock head.
Decking the block and using only the mid and lower pieces of the head gasket? is this an option or would i need the came gears because of the dcrease in clearance?
aol: GregTMFM
Old Jul 27, 2001 | 07:59 AM
I know the CTR pistons Comp is not to high but im wondering if the top is to high is the quench area large enough so that nothing taps? If so ill go withctr pistons but im just not sure.
aol: GregTMFM
Old Jul 27, 2001 | 07:00 PM
KJ's Avatar
KJ
bored at work
Stick w/ under 12:1. Running 12:1 is at the very edge of what is possible to run on pump gas and keeps you from being able to advance ign timing. Unless your planning on running some very big cams you will be able to make just as much power and be more reliable running about 11-11.6:1 w/ timing advance.
Comp numbers:
lsvtec b16a head w/ usdm itr pist ~ 10.9:1
lsvtec b16a head w jdm itr pist ~11.2:1 (best choice)
lsvtec b16a head w/ usdm b16a pist ~ 11.6:1
gsr head will yield a little higher c/r
Old Jul 28, 2001 | 05:11 AM
any idea what compression i will be putting down the the usdm b16a pistons because i can get thoughs for free.
b16a jdm pistons compression is 10.4:1 how come so much higher with new block? The stroke changes compression by over a point? Never knew that.
aol: GregTMFM
Old Jul 28, 2001 | 10:12 AM
KJ's Avatar
KJ
bored at work
Originally posted by "Someone"
Originally posted by hybridEG
k.j. where did you find those number?
Calculated them.
lsvtec b16a head and usdm b16a pist ~ 11.6:1
lsvtec b16a head and jdm pist ~ 11.8:1
Old Jul 30, 2001 | 04:14 PM
Iroc Joe's Avatar
AuH20 in '64
My old CAR had 22:1 compression and enough fuel pressure to cut your fingers...what was it Fuel pressure was 8000 psi..I shit you not. A dollar to the victor..and it was STOCK...and dont bother arguing the 8000 psi..it was int he service manual
“If someone is so fearful that they are going to start using their weapons to protect their rights, it makes me very nervous that these people have weapons at all.”
U.S. Representative Henry Waxman (D-CA)
Originally Posted by XYNaPSE
Article I Section 8 gives Congress the power to do whatever Congress deems necessary.
