what is this and y is it leaking?
Old Jun 22, 2008 | 10:26 AM
wasrelgood's Avatar
Default what is this and y is it leaking?
well in tampa it rained for hours yesterday and last night. i checked my car this morning and smell sitting water. i feel around and feel a wet carpet. long story short this thing starts randomly leaking rite in front of my eyes.
how do i repair this little problem?
this is wats leaking.
Old Jun 22, 2008 | 11:12 AM
1nycelude's Avatar
***boosted***
its hard to tell but i think that is for your ac unit they get blocked up once and a while if you get under the car you will see a tube under there that lets the water drain out of the unit it is prob. backed up take a air hose and blow it up in there. and then you should notice water coming out after you unblock it.
i once felt bad cause i had no turbo!! then i met a man that had no VTEC.
Old Jun 22, 2008 | 11:15 AM
wasrelgood's Avatar
ok. hope that works. but i dont ever really use the ac so this is a weird proble, i hope the little air trick works cuz i cant deal with water in my car. hahaha. thanks.
Old Jun 22, 2008 | 11:28 AM
Blue92ludesi's Avatar
you drive a 94 teg? according to your avatar info.
Good luck, all 92-95 civics and DC integras have that issue along with some other older hondas.
There was a TSB back in 96-00 honds skimped on the firewall seams with seam sealer, the stuff gets old and cracks and water leaks in through the seams. Right over the blower motor. Thats what you have a picture off, the blower motor. Honda no longer fixes this. So you have 2 options, deal with it, or do it yourself. Ill try to find the TSB
Honda of Wesley Chapel Crew Member #1
TR 5th Gen Civic CREW Member # 07
TR H2B crew #2
__________________________________________________ _________________________________________________
Old Jun 22, 2008 | 11:45 AM
wasrelgood's Avatar
"the water is coming in from under the cowl area in front of the windshield. Search for passenger side water leak. "
this is wat someone on honda tech told me. . have u ever had to fix this problem befor?
Old Jun 22, 2008 | 11:48 AM
lzylst's Avatar
The cowl will catch water from rain as well as fresh air.
Vance @ 863-604-2139 for any questions
Old Jun 22, 2008 | 12:02 PM
wasrelgood's Avatar
well it just rained hard again and i think its coming from the rain. buh how is it gettin in the car?
Old Jun 22, 2008 | 12:25 PM
MTXaudioSYSTM's Avatar
Slow V6 Firebird
1+ happens to me alot
Old Jun 23, 2008 | 10:27 AM
wasrelgood's Avatar
wat can i do. how can i fix it?
Old Jun 24, 2008 | 03:50 AM
dippincrx's Avatar
save the s.o.h.c
trace it down. coming threw your fresh air at the cowl most likely. on a dry day spray it down w/ a hose and look where its getting threw. pull the plastic trim off next to the windsheild and hood when you do it
