have ? concerning the f22b swap into my 93 civic dx
Old Jun 15, 2008 | 07:32 PM
WISH.HAD.MO.MONEY's Avatar
Default have ? concerning the f22b swap into my 93 civic dx
i have a 93 civic dx an just bought a jdm f22b dohc non vtec. was wondering if the mounts for the h23 are the same as the f22. also i am worried about the shift links an which ones i should use. not to bright on the whole what works with what. also there is a hole in the block to where the water pump bolts up to, you can see the propeller in there i know there is supposed to be something there. well i think this will help for now an would like anyones comment on this to help me out. thanks
Old Jun 17, 2008 | 10:52 AM
dippincrx's Avatar
save the s.o.h.c
h mounts and f mounts are the same. i think on accord trannys you just have to drill the bosses out and tap them to run the trans swap mount. is the hole you see on the back of the block? there is a pipe that is suppose to run from water pump to tstat housing. bisimoto makes a f/h to d mount kit. pretty expesive but simplifies swapping. keeps orig axles d series clutch, trans, linkage
Old Jun 17, 2008 | 02:27 PM
Blue92ludesi's Avatar
PM me for any F/H related questions.
Honda of Wesley Chapel Crew Member #1
TR 5th Gen Civic CREW Member # 07
TR H2B crew #2
__________________________________________________ _________________________________________________
Old Jun 17, 2008 | 07:53 PM
so what keep my original shift link an cv axles. an yes the hole is right behind the wp an you can see the prop. its a basic block head deal for 400 bucks. my 1.5 blew a head gask so dont want to put money into it really. thanks for the info i will keep intouch due to the knowledge you have over me.
