starting problem
Old Jun 14, 2008 | 08:40 PM
LShatch98's Avatar
i love making you mad <3
Default starting problem
car: ek hatch ls swap.
it starts prefect when its cold. but after i drive it around for awhile then stop and shut it off like to run in a store or getting gas(still hot). i go to start it again and it starts the dies out. if i dont feed it gas n keep the rpms up after about 10 sec if will idle but it will be rough like its misfiring. i have change the fuel pump,spark plug wire and plugs,and the fuel filter so far the filter helped a little bit. ne ideas?
Proven Power for all your go fast needs
Old Jun 14, 2008 | 10:17 PM
mtber's Avatar
Main relay or ignition control module.
Old Jun 15, 2008 | 05:12 AM
89crxsir's Avatar
+1 ignition control module, mine is doing the same. already changed the main relay
SEE NO EVO HEAR NO EVO!
If i put half a tank of Shell V power, and half a tank of Chevron with Techron. Will i get v-tec??
Old Jun 15, 2008 | 07:42 AM
LShatch98's Avatar
where is the ignition control module located?
Old Jun 15, 2008 | 12:00 PM
89crxsir's Avatar
it's in the dizzy with 4 wires coming off of it. it should have 2 screws holding it to the dizzy case. make sure to you get die electric grease for the new one. smear it between the module and the metal plate to you take off
Old Jun 15, 2008 | 12:21 PM
LShatch98's Avatar
thanks alot. rep given
Old Jun 15, 2008 | 12:49 PM
89crxsir's Avatar
Make sure you mark your dizzy, so you know where is in time. turn it towards the rear of the car is advanced. and also remember where your rotor is at..
