clutch troubleshooting (won't disengage)
Old Jun 11, 2008 | 09:10 PM
FL_civic_rider's Avatar
Drive it like it's a Taco
Default clutch troubleshooting (won't disengage)
ok so car is a 95 integra LS hydro tranny
clutch was going out bad so i just replaced the clutch, pressure plate, throwout bearing.
and now I can't get the clutch to disengage...
car off I can't disengage it and if i start the car it starts moving.
Bled the hell out of the slave and there's nothing but clean fluid coming out with no more air bubbles.
clutch master and slave cylnder were fine before the swap so i don't think it's that.
any clues or ideas?
Contact me:
Adam B.
Cell: (727) 742-0633
Old Jun 11, 2008 | 09:14 PM
TheRedDragon's Avatar
sound like pressure plate isnt TQ down right or throwout bearing isnt right
ALPHA TUNED
Tuning, Builds, Assembly, Turbo Installs, Repairs and More
inductionperformance.com
Old Jun 11, 2008 | 09:31 PM
/shoots self
I really don't wanna pull the tranny out again to find out lol /cry
i guess i'm gonna have to try
also, when i pulled everything off, there was NO flywheel bearing installed...
when i reinstalled everything should i have put the new flywheel bearing in even though there wasn't one present before?
Contact me:
Adam B.
Old Jun 11, 2008 | 09:49 PM
yes
ALPHA TUNED
Old Jun 12, 2008 | 02:01 AM
lzylst's Avatar
Did you install the throwout bearing?
Vance @ 863-604-2139 for any questions
Old Jun 12, 2008 | 05:47 AM
1nycelude's Avatar
***boosted***
i bet it has to do with the pilot bearing it must not be right. did you have a hard time getting the tranny set back on to the motor? it sounds like the input shaft of the tranny is lodged in the crank/flywheel of the motor making them like one piece which would take the clutch out of the loop and make it almost to where it doesnt exist. do you have a good pedal feel at the clutch and can you watch the clutch fork have a good amount of throw down at the tranny. little more info please.
i once felt bad cause i had no turbo!! then i met a man that had no VTEC.
Old Jun 12, 2008 | 08:19 AM
Yes i installed the flywheel bearing-
Yes I installed the throwout bearing-
Tranny slipped in just fine no problem, yes clutch pedal feels fine and yes i can watch the clutch fork press and depress back and forth
Contact me:
Adam B.
Old Jun 12, 2008 | 11:18 AM
1nycelude's Avatar
***boosted***
sorry that all the help i have if you could bring it to me i could fix it but its hard over the internet.
Old Jun 12, 2008 | 11:40 AM
+1
ALPHA TUNED
Old Jun 12, 2008 | 10:14 PM
it's all gravy guys, I've got neal coming over saturday to take a look at it, we'll see what i fucked up
Contact me:
Adam B.
