shifter wobble after misshift
Old Jun 10, 2008 | 11:38 AM
HonkeyDong's Avatar
Every dog has his day.
Default shifter wobble after misshift
the other day i was redlining gears and somehow i went from 4th to 3rd on accident. Now after that when i push the shifter to the right in neutral i hear a small metal on metal grinding, but it sounds like its coming from the actual shifter itself, not inside the transmission, so I think my syncros are ok. Also now in 5th gear while cruising my shifter wobbles like crazy. Anyone have any idea what the problem could be?
When I look under the car and move the shifter back and forth in neutral, my exhaust moves down a little bit. Is my shifter hitting my exhaust causing the rattle/movement?
Mattbuilt
AEM | Mugen | Skunk2 | Hasport | Hondata | Koni |Ground Control |
Old Jun 10, 2008 | 12:28 PM
amimaxima's Avatar
shifter bushing?
Old Jun 10, 2008 | 12:49 PM
HonkeyDong's Avatar
why would there be a metal on metal sound though? I can't get under my car to check everything out right now.
Mattbuilt
Old Jun 10, 2008 | 01:15 PM
sprjit22's Avatar
Rick James bitch
1st step would be to get the car in the air and inspect
TR 5th Gen Civic CREW Member #14
T & C Racing
What VP Race fuel's should we carry?
FT Crew Mascot lol
Gotta love my hater fan club. I love the fact people worry about me 24/7 Ill never be forgotten. I love you guys.....
Old Jun 10, 2008 | 06:48 PM
freakasis's Avatar
check the shifter bushings, then undo some of the exhaust hangers so the exhaust sits lower and drive it around a bit to see if the exhaust is the problem....but i have a feeling you bent somthing in the tranny by slamming the shifter too hard. good luck
Old Jun 10, 2008 | 06:53 PM
HonkeyDong's Avatar
But i can see my exhaust move when i move it around in neutral if im looking under the car.
Mattbuilt
Old Jun 10, 2008 | 07:04 PM
freakasis's Avatar
that doesnt mean anything....my stock civic with a short shifter did that. and it had no shifting noises or problems....like i said try to drop the exhaust down and see if that helps...if it does no biggy just ignor it.
Old Jun 10, 2008 | 07:18 PM
HonkeyDong's Avatar
well i couldn't take it any longer so I just went out and took a look under my car. The metal/metal contact noise I hear/feel is definitely the bottom of the shifter hitting on the exhaust heat shield. This somehow happened as a result of over revving. The D bushing is almost fully out of place, i have ES bushings sitting on my dresser ready to go. So I need to figure out why the shifter is now lower than before, and put the new bushings in, change trans fluid and see how the car feels from there.
Mattbuilt
Old Jun 12, 2008 | 09:50 AM
HonkeyDong's Avatar
ok here's the deal. The bottom of the shifter and part of the shift linkage was for some reason rubbing on the top of the exhaust heatshield. I took off the heat shield and hammered it down a little bit so it didnt hit. I also installed new polyurethane shifter bushing and flushed my transmission fluid and put in honda genuine manual transmission fluid. My shifting feels better than it ever has before.
Mattbuilt
