HELP ok i was driving my civic type-r just got it
and i went through a small but deep puddle an my intake sucked up water it starts and runa and drives but it knocks i think its a rod or piston cracked i dono dont wanna pull apart yet but the water was dripping a good bit from filter of intake in my garage an now i am scared to drive
yet agian HHHHHEEELLLLPPPPP
lol hydrolocked
Like us on facebook
Like us on facebook
check this out, intakes, pistons, valves, and rod don't like water and cold air intake and florida don't make a good couple either, it usually ends up in a nasty divorce....im just messing with you lol....you are going to have to rebuild the motor if the sleeves are ok in there. i can come take it apart and rebuild it or put a new motor in it if you need to...pm me....
PM me for any AC, audio, and wiring work on your vehicle. Including but not limited to car audio, alarms, gauge installs, custom clusters, full troubleshooting, big/dual fuel pump relay kits, battery relocation, factory radio iPod and amplifier integration, custom harnesses, and custom standalone ecu installs and much more! If you need it done, we can do it! Don't be afraid to inquire!
engine building &best
on
yup sounds like a Bent rod,That sucks JUST MAKE sure you dont keep trying to Restart it or you may start damageing the cyl walls Then your in deeper
i love AUTOZONE
i love AUTOZONE
Happened to me in my Daewoo during that freak rainstorm in February '06. Pulled the plugs, cranked the motor, sprayed WD-40 in the cylinders, put the plugs back, fired right up. Still running to this day, no compression or valve issues. Thank God for incredibly high Korean engine tolerances.
Generally the drop in air pressure will stall the engine out before MAJOR damage can happen. You WILL get some water in the cylinders, but it isn't fatal.
The fact that you started it without trying to dry the motor is your problem. The fact that it knocks already makes me wonder what kind of help you're hoping for...
You need a rebuild.
You need a rebuild.
