what do you guys think???
Old Jun 8, 2008 | 09:20 AM
rangcrx's Avatar
engine building &best
^ it will only get expensive when you waste money on things not needed like ANY angle job or porting work,that is not needed on a street car.the forged rods are better in to many ways,one less chance of spinning bearing,he could use stock but if he already has hbeams his better off.and on a almotor nice tune stock pistons are fine
i love AUTOZONE
Old Jun 8, 2008 | 11:55 AM
Bori300's Avatar
Bori300
Originally Posted by chimmike
don't waste the money on a valve job if you're only doing 3 angle dude. That's a waste of money. If you want a "mean" all motor build: 5 angle valve job with swirl and quench areas, full port/polish of head to match the intake mani, and a good 4-2-1 header with at least 2.5" exhaust. Probably gonna need valvesprings/retainers/LMA's and get some light aftermarket valves.
Also....why do eagle rods if you're going to stick with OEM pistons? Seems to me it'd be better to do OEM rods as they're lighter.
I'd do some forged high-comp pistons so the ring lands aren't as high as stock (less prone to cracking should detonation occur), and I'd get the whole rotating assembly shaved and balanced......the lighter it is, the more freely it'll rev, and balancing it will prevent any harmonics issues from occurring.
Sounds like you'll need cam gears to tune the cams well.
This is gonna get pretty expensive pretty quick dude. You consider the cost-power vs. going boost?
well bro all that sounds nice an all but like u said it can get expensive and its just gonna be a street car that i can drive around 2 work and stuff... well i already have the eagle rods it came with the longblock...
TR 5th Gen Civic CREW Member # 17
TR "Old Skool DA" Member #55
Old Jun 8, 2008 | 11:57 AM
Bori300's Avatar
Bori300
eaxctly.. hay bro did u get my pm??? and ima post up a pik of the ls piston on the eagle rod.. and how much would u charge me 2 grove the itr psiton.. also do u kno of a place i can go 2 get the engine honed???
Old Jun 8, 2008 | 12:35 PM
Bori300's Avatar
Bori300
pics are up
Old Jun 8, 2008 | 02:06 PM
rangcrx's Avatar
good news is you can use thos pistons they look like Je pistons thos are aftermarket im sure if you needed to you can sell them for someone building a turbo build.or you can use them and get to use 87/89 gas : o )
i love AUTOZONE
Old Jun 8, 2008 | 03:10 PM
Bori300's Avatar
Bori300
i thought they were ls pistons.. only prob is the pistons r messed up.. ima post u a pik of where its messed up.. and im sure i cant use them like that... where can i buy pistons like those??? and are they better than the itrs???
Old Jun 8, 2008 | 03:32 PM
  #17 (permalink)
Bori300's Avatar
Bori300
Old Jun 8, 2008 | 04:28 PM
  #18 (permalink)
rangcrx's Avatar
what the hell is that?did that hit a gsr head?
i love AUTOZONE
Old Jun 8, 2008 | 06:19 PM
  #19 (permalink)
Bori300's Avatar
Bori300
bro 2 tell u the truth i dont kno... the head dosnt have any sighs that the piston would have hit it..
Old Jun 8, 2008 | 06:21 PM
  #20 (permalink)
Bori300's Avatar
Bori300
so what should i do??? go with the itr psitons and get it groved so it will work on those rods??? and i need a hone also
