what injectors to use?
ok so heres what my new set-up is gonna be....
B18C5 with endyne high compression pistons(12.0-12.5:1)
B16 head, with Toda Spec B's
Inline pro ported/shortened B16 manifold
Hytech replica header
walbro 255
stock fuel rail and filter
gonna be converting to OBD-1 and getting a tune, now what size/type of injector should i use with this set-up?
thanx in advance for any usefull info
walbro 255
you can use high impedance inj. if you remove the resistor box, or if you use low impedance, you must use the resisitor box
1992 Honda Civic Si: SOLD
2003 VW Gti 1.8t: SOLD
Most recent: 88' B16 Turbo CRX: Totaled
PM me if you know me!
I would just pick up whatever you cna find cheapest . I would suggest some Prelude 290's or perhaps some Peak and Hold 310's form RC .
Setup should make 210+ so you will need atleast some 290's
Hondata saves lives
Hondata saves lives
you ever find out the info on the VSS situation? i may just swap out for the DC cluster instead of the DA then just run a signal for the cluster aswell as the ECU?
but anywho jap give me a call about getting this thing tuned. im hoping to try and get it together by this coming weekend.
310cc injectors would be ideal for your setup.
Precision 310cc saturated injectors are very affordable brand new.
$210-220 is about the cheapest you will find them.
ok. what would be a good choice on rods? i was told to just use an H-beam to decrease the likely ness of a spun bearing.... im no engine builder/tuner by any means so any light you can shed on this area would be helpful.
