Need Help Now
i have a d16a1 (zc) dohc. theres sohc internals and im wanting to know if im able to put a sohc head on the zc. if so what do i all need?......... . ........
NEW QUESTION, i just bought the motor saying d16a1 whitch is the dohc as well but the cams say pm6 as mine (zc) says pm7. can i use my cams in the d16a1 head????
Heh... ive seen that car before... Did you get it from a girl named Cindy? in polk city??
Anyways i think you can stick a Single cam head on it as it is a single cam sort of....
well you would need a Single cam head. head gasket and what not...
Im pretty sure you can not do that and you will have hella problems tryin to make it work just get a single salam motor and be done if you need help lmk.
Cory
Cory
CAM-Mobile-Performance&Repair
For All Your Performance And Repair Need's
Done At Your Spot Or Mine.
Cory .M
I do every thing from ECU chipping, swaps and custom wireing to audio and alarms, even suspention and alignment's.
We will be tuneing very soon E-MAIL me at CAMPERFORMANCE@yahoo.com
For any questions or to set up an appt.Cory .M
think about this for a second bro....
you have a dual cam zc motor. you want to put a single cam 1.6 head (which has 1 cam instead of two) on a motor that 2 cams instead of one. got it?
the answer is simply no.
but the pm6 is d16a6 (88-91 si/ex motor)
MARKTOPIA I can do on the spot alignments, but if you need camber adjustments you will need to get excentric (or how ever its spelled lol) bolts or some other form of a camber kit witch I coukld also install and align.
So lmk so we can work something out.
Cory
Cory
Cory .M
d16a1= 2 pm6 cams
its also a dohc motor with sohc internals. if it was a sohc head then im not retarded. thanks tho
There was no need for that guy to be an ass. but he is right it will not work.
I hope the alignment info helps.
Cory
Cory
Cory .M
'86-'87 D16A1 = stronger rods, vac distributor, blank engine ID
'88-'89 D16A1 = lighter rods, higher comp pistons, elec distributor, larger intake plenum (manifold), stamped D16A1 on engine ID.... i bought <
'86-'89 D16A1 ZC = same as D16A1, but more agressive cams and larger intake plenum.... mine that blew <
'88-'91 Honda D16A8/9 ZC = same as D16A1 ZC, but motor mounts are different.
